Lou Hamilton
add the difference of the new tire to what is by default in FORScan. What’s there takes in account the weight of the vehicle squishing the tire down! Again why I only added .5” (12MM) to my tire height.
Also, you don’t need to input/mess with the HEX in FORScan. Just go into this and add the new +X MM there. Then go to TCM relearn & clear the DTCs. BAM your good!
If that still throws the wrench but you have accurate speedometer then a custom tune you will need!
It doesn't really bother me and it seems like it doesn't cause any issues.
A tune was something I was considering at one point. Not sure when, but maybe some day. :)
DWs-TTEB
Evans, GA
I love the tunes I got from 5-Star! Just called Hellwig, they said it takes them 11 weeks to ship from order date their sway Bars!! I ordered mine on Dec 25, 2020...so sometime in late March I will be getting them. Hopefully I get my order of Bilsteins before that. Ordered them on Jan 5th, 2021.
Tys expedition
Phoenix, AZ
Snapped half the mounting tab off the running boards this weekend. Not a lot of wheel travel or clearance on these big luxo yachts. Set it on the ground a couple times going over ledges this weekend.
DWs-TTEB
Evans, GA
Do you have any rubbing? Those fronts look like they would hit something at full lock.
No rubbing that I can hear or feel at full lock left or right. Now since the wheel well liners are made of cloth of some type they will probably mask any light rubbing noise/vibrations. When I get the height adjustable Bilsteins I won't have to worry about hitting the liner under light load traversing some dirt n opportunity. After a few more miles if it is lightly rubbing it should leave a mark on the liners.
Lou Hamilton
I might have to go get some skinnier tires tomorrow because of you two !
It does seem that the 285 and 275 width is the sweet spot for these vehicles.
Your 12.5’s are a bit too wide. I’ve seen a few 305’s posted, but cant’ remember if they have any rubbing. I know 315’s do, because Kent had to do some zip tie work on his Raptor wheels with the Navy on no lift.
sjwhiteley
Kentucky
Added on Spartan pod lights yesterday
Those look nice. I went with some smaller Rigid. But I have a question; how/where did you run the wires for each side to the power? Doesn’t look too difficult, but I can’t see anything too neat.
Big H
New Jersey
There’s a good amount of room to run wiring in the engine bay and around hood hinges. Also the firewall plug and area under driver dash also has space in the kick panel to hide the remote/strobe modules and run manual switches. See pics below of how I ran and fastened the wiring.
Big H
New Jersey
Pro tip: [emoji16]
When routing the wiring unbolt (circled in red) this panel and slide wiring under it for a cleaner look and to keep it out of the way from being pinched under hood. You can also route the positive circle connector for the battery under the red corrosion cover for a cleaner look.
Also have these fasteners on hand, as you will most certainly break 1 of 3 that need to be removed from the windshield cowl for light C- mount install.
sjwhiteley
Kentucky
excellent! Looks like you used the ‘contracting’ loom cover. Hadn’t thought of using some of that (I have some split wrap plastic).
Big H
New Jersey
Yes that’s correct; offers similar protection and more flexibility, tighter wrapping, and space saving.
Fozzy
Riverton
Was the harness for the A-pillar lights as good as the bumper bar?
BLUWAGN
Iowa
Picked up some F150 Platinum Wheels/ OEM Hankook ATM for a winter set and finally got around to putting them on. Also installed 5mm hubcentric spacer on the front and 10mm hubcentric/wheelcentric spacer on the rear to even up the 10mm track difference that the expedition has and to alleviate issues with clearance of F150 center caps. My wife isn't sure on the 20" look yet but the tires will perform on snow much better than the factory 22" rubber and I have many more choices for winter rubber moving forward.
5280tunage
colorado
Nothing big but you guys finally talked me into blacking out the C-Pillars. Couple things from my experience.
First, I tried to use the 3M cutting tape in places, I just didn't want a blade against my paint as much as possible. The tape worked for the most part but it's definitely harder than the pros make it look. But where it worked, it was nice.
Second, I used the 3M 2080 series as it seems to be the best on the market, I like that it has both a backing and a protective liner, makes it easier to squeegee out the bubbles. but one thing I noticed was that this stuff scuffs/scratches super easy. After applying it, I wiped it down with a freshly washed microfiber cloth and it still scuffed a bit. That will take some getting used to.
Definitely didn't do a perfect job but given it's be 15 years since I did any tinting and clear bra, it went okay.
