carymccarr
The Lincoln is just a little bit too classy for me, so for me the easy choice was the Ford, also on the 4WD version, on the Lincoln Navigator, you only get a 1 Speed Transfer Case, but on the Ford Expedition, you get a 2 Speed Transfer Case, so no 4X4 Low Option on the Lincoln. Glad I picked the Ford
Not accurate. As I understand it:
There are two rear wheel drive modes (2H):
Normal - 2H - Rear wheel drive.
Conserve - 2H - Real wheel drive. Shift points, suspension, etc., changed to give you better gas mileage.
There are three all wheel drive modes (4A):
Normal 4X4 - 4A - All wheel drive mode for general on-road driving.
Excite - 4A - All wheel drive mode with a performance emphasis.
Slippery - 4A - All wheel drive mode for less than ideal conditions. Lowers throttle response, changes shift points.
There is one traditional 4X4 mode (4H):
Deep Conditions - 4H - This is a traditional 4X4, Four Wheel Drive, for mud, snow, sand, etc. It is not for use on dry hard surface roads.
There is one 4X4 Low mode (4H):
Slow Climb - 4L - This is a traditional Four Wheel Drive, Low gearing, for slippery steep grades, pulling a boat out of a launch ramp, etc. It is not for use on dry, hard surfaced roads.
(Pulled from Lincoln forum)
