Cost of New Brake Pads and Rotors
What is a reasonable price to pay for new front pads and rotors on a 2013 Expedition 4x4?
Probably need to be more specific; OEM Motorcraft pads and rotors? Cheap, poor quality made-in-China pads and rotors? Or something in-between?
Lets go with OEM.
I had all four rotors and pad sets replaced on my 2015 Expedition (purchased new) with OEM Motorcraft parts at about 45,*** miles. My son did the work, so I can’t give you a fair price with labor.
On all vehicles I have owned (50 + years), I have always purchased OEM brake pads and rotors. I used to do the work myself, but no longer can due to surgeries.
The brakes began to shimmy early in the warranty period, although I do not tow or haul heavy cargo (passenger use). The dealer turned all four rotors, which I believe caused them to wear-out prematurely.
I’m not sure what the book-rate is for labor, but I would believe it would be 1 1/2 - 2 hours of labor (but I think most experienced mechanics could do it quicker, as it is simply remove and replace parts - and using brake lube).
Trainmaster
Old School Member
Rockaway Beach, NY
OEM Parts from Tasca Ford:
Rotors $ 70 each
Pads $ 56 per axle.
Hardware $ 30 per axle, but most "mechanics" don't replace it.
If you want to mess with parking brakes, add $60 parts.
Around here, labor at a local garage would be $225 per axle; a dealer would charge about $350/axle labor.
"Rebuilding" the parking brakes adds another hour's labor $125 for a garage, $210 for a dealer.
A dishonest shop would add useless services like "brake line flush." cutting the new rotors, environmental fee, etc.
dakotazeb
dakotazeb
South Dakota
Thanks guys. I've been quoted any where from $330 to $615 for new pads and rotors on the front axle only.
JasonH
Houston, TX
I just did this job on my 2017 a month ago. It's a simple DIY if you have done brakes. Just get a three jaw puller from Harbor Freight and don't leave the e-brake on while pulling the rears like I did. ‍♂️ Easy peasy.
RichardH
TX
I used Detroit Axle brand via Amazon. A friend who is in chain supply management mentioned the brake components (rotors etc) are manufactured by a few companies - usually in China. Maybe not 100% accurate, but see the next article.
Ford OEM parts sourced from China... worth reading.
https://www.autonews.com/article/20051205/SUB/51202050/ford-sources-aftermarket-parts-from-china
Here is a link to Detroit Axle F/R package on Amazon for the 2013 expy- $199.25 with hardware. Maybe consider it.
https://www.amazon.com/Detroit-Axle...------------&vehicleName=2013+Ford+Expedition
I did the front on my '03 with the Detroit Axle kit, all hardware, brake fluid, brake cleaner included and all is well. No noise from the pads, great performance.
Just worth mentioning.
Dick
dakotazeb
dakotazeb
South Dakota
This is all great guys but I'm not a do it yourselfer. My question of cost was having it done at a dealership or reputable auto repair store.
Trainmaster
Old School Member
Rockaway Beach, NY
The prices you received are right in the ballpark. You have to see whose parts you are getting. I'd stick with OEM or just about any major manufacturer. Very many garages give you the cheapest junk they can buy, and there's some real garbage out there.
RichardH
TX
Some independent shops needing the business will allow parts to be brought in, if not a DYI'er.
For some jobs I can't tackle I have an indy that prefers I bring the parts in. The Detroit Axle parts do have a 10 year warranty.
JasonH
Houston, TX
I usually call three to five shops in the area for a quote if it's something I can't do.
RichardH
TX
Good idea. I'll usually use a shop for a small job to see how they handle the customer first. I looked in SD for an NTB (National Tire and Battery) but does not look like they are there. I do my own brake jobs - rotor replacements, but their pricing for oil change/semi-synthetic cost it's easier to take to them to deal with it. Brakes, other small components are different. EGR system components, hoses, COP's, filters etc I'll do.
A dealer would of course be competent to do the job, but you'll pay a premium.
I was forced to take my truck to a dealer and it even took them 3 visits and 2-3 days down each time per visit. Last visit they paid for my rental car for 4 days. Long story. Short version - they had to fabricate a wire harness from scratch - none available anywhere in the country. Battery cables, starter cable, fusible link. All's well now.
Do the above, call a few, visit the shop. Look for maybe a shop that only does brakes. We have some on those in Houston. Unsure about your area. I've never been unhappy changing out to ceramic pads on these trucks.
GL
Aspen03
Indianapolis
I would highly recommend the Powerstop Z36 kit from Rock Auto. Great stopping power, drilled rotors for cooling, ceramic -CF pads for a powerful stop.
https://www.rockauto.com/en/catalog...brake+&+wheel+hub,rotor+&+brake+pad+kit,13824
These are great, I also installed these back in July and they are likely the best set of pads and rotors I've had on any vehicle. They stop well, very smooth..no movement in pedal under moderste/hard braking, and look nice. I would see about using your own parts regardless of where you take it. If a shop says no and you're trying to bring in a quality component I'd take business elsewhere. If $100+ an hour isn't enough for them to want your business if you won't buy the overpriced parts from them they can shove it.
The pricing you've posted seems to be in line with what I would expect w labor. Definitely find out what components are being included, there isbam awful wide range of quality and cost for parts. You can easily find per axle cost of parts for $100 or less and then if you're paying the remainder in labor I would say that's fairly high, even at a dealer $230+ an axle seems exorbitant. In my experience if you don't ask for something specific you usually get the bottom basement quality components that maximize their profit.
vincentrose
Kershaw, SC
I just recently did a Rear Brake Jobs, New Pads, Rotors, Parking Brake Shoes, and Hardware, all Motorcraft Parts (except for the brake hardware, got Raybestos there) all for $308 from Rockauto. Did it all myself on a Saturday.
