PATS issue, no start, no crank.
Thunderbirdsport
Missouri
Have two keys, both were working with no issues. About 2 weeks ago when it got really cold, I'd insert a key, turn to start, and nothing would happen for about 5 seconds. Then the cluster warning lights would come (as normal) and then it would be able to be started.
Today, when the key is turned to start, nothing. No cluster warning lights, no start, just that damned PATS light blinking steadily. Either key does the same thing.
I searched, couldn't come up with much other than one fella had his start/run relay replaced at Ford.
Before I drag it to the shop tomorrow, anything else I can try?
I did hook the forscan up to it but it says it can't connect. Not sure if that's a side effect of the PATS locking things out or what...
And to really shit on my parade, my Explorer has a head gasket leak. None of my other vehicles are licensed, the one that does otherwise run needs diff work and isn't safe to drive.
Thunderbirdsport
Thunderbirdsport
Missouri
That didn't work, with either key. Going to let it sit with neg batt cable discoed for a couple of hours. Had a lot of Fords under my care, never EVER had one with PATS issues. Is there a way to put a tuner on and disable this shit completely?
I don't need/want it, especially if it will leave me with nothing but driveway art....
Poland
Been there buddy.
Ok. BTW: do you get dashes instead of your mileage or your mileage is shown?
If it's shown, it means the Instrument Cluster talks to PCM.
1. Check if you have power to the PCM (in my case - 2007 Expy, it was PIN 8 in connector C175B ). It should get the same as power measured at the battery. If you are not getting power or power is lower than from the battery then there is a problem, likely in the wire leading to engine bay fuse box.
2. replace PCM relay in engine bay fuse box with other relay that you know works (you can use for example the one for blower).
3. Check the fuse for transponder receiver or it's something called like that - in the fuse box by the front passenger.
4. Check if you have grounds in connector C175B - bottom 4 plus I think PIN 66.
Trainmaster
Old School Member
Rockaway Beach, NY
I'd go with Mike's advice. Sounds more like a voltage problem than a PATS problem, though I'm just guessing.
Relay contacts, corroded connector, etc... especially since it seems to be getting worse. Electronics usually just outright die.
Thunderbirdsport
Thunderbirdsport
Missouri
This morning, after I'd checked all of Mike's suggestions (of which none had any favorable results, I decided to throw in the towel and called for a rollback to bring the Expy to Ford. Since it's thawing here, the driveway is a muddy disaster, so I decided to pull the Expy down to the end of the drive. The girlfriend was in the Expy, I'd already bypassed the shift interlock and had it in neutral and was preparing to hook up a towrope. She started the damned thing, just to see if it would. Scared the hell outta me, as I was hooking the rope to the front tow hook LOL.
So I got in the pass side, turned the engine off, restarted it. I did this a couple more times, then it wouldn't start again. (By this time I'd put it back in park, despite it being on rather soft ground...it wasn't going to roll anywhere but why chance anything?)
I bypassed the shift lock again, put it in neutral, and it started again.
So I left it running, she got in the Explorer, and I drove it to the local Ford dealership.
They couldn't replicate the problem, though they had it all day. They called me about 430PM and asked what I wanted them to do with it as they were closing in an hour. I went and got it and it's continued to start fine.
I'm starting to think it's temperature related. Their shop is heated and it got up to 53 today. I'll go out later after it's sat for a few hours and see what it does.
The tech did say there were no codes, and he too checked all the grounds, the PCM, the start/run relays, and even suggested that the PATS wasn't the issue as according to him when that fails/activates the dash light flashes very fast.
I'll try it again later and see what she does. I'll update with findings. Stay tuned.
sjwelds
Kansas
My 08 acted similar once. Turn the key and nothing. Try it again, sometimes nothing, sometimes start. Took it to an independent mechanic, whom I've used for years and trust implicitly. Could not replicate. He switched some relays around with some lesser used relays, and had me come get it.
Never had that problem again while we owned that vehicle.
Thunderbirdsport
Thunderbirdsport
Missouri
It started last night after it had sat for a few hours, and again this morning. Will be a little while before I trust it on a long trip, but so far so good. I'm still not entirely convinced the bitter cold didn't play a part in it, though. It has been below 33 degrees the last 3 nights..
Thunderbirdsport
Thunderbirdsport
Missouri
And as of yesterday afternoon, we're back to the no-start. Talked to a Ford wrench, he said the only other time he'd seen this, he had to replace the cluster.
I've checked every relay and fuse that is in the circuitry for cluster, PCM, and shift interlock* (more on this in a minute) to no avail, everything is good. I even switched all the relays around, still no start.
*Friday when I preparing to drag the Expy to the end of the drive to have it towed to the dealer, I had the console opened up and manually bypassed the shift interlock. While it was in neutral, it started. I shut it off and started a couple of times and on the third try it wouldn't start up again. By this point I'd placed it back in park. I again manually bypassed the shiftlock and it started again. After that, it always started in park. The times it won't start, you can NOT get it into neutral, even with the brake applied, UNLESS you manuall hold the interlock tab open and bypass.
The only thing that's lit on the cluster when the no start occurs is the steady, every-2-seconds blink of the anti theft light. No other lights come on, as they should when the key is on but engine off.
I'm not too sharp on the cluster swap process beyond the mechanical bit of removal/reinstallation....is there programming to be done to get it to communicate with the PCM and other systems? At this point the mileage is the least concern, I just want the damned thing to start and run reliably.
A used cluster isn't too cheap, but nor is it a life changing purchase. If that's what I need then it's a non issue, but I hate to spend 100-some bucks to throw a part at it, much less the programming work at Ford and it's not the solution to the issue.
The only other thing I can think of is something in the wiring, but barring a temp related issue (it's been no colder than 40 and no warmer than 50-52 the last 3 days, and it ran Friday, last) I am stumped.
The tech at ford couldn't replicate the problem and seemed to think that PATS wasn't the issue, he said the anti theft light would blink rapidly, fast than a blink every couple of seconds.
Has anyone here had to replace the cluster?
There's something wrong with the board, search is not working, and the site itself is extremely slow and keeps giving error messages. The only other info I have to go on is on the truck forums, and I'm not entirely sure the issues about clusters being bad, causing no-starts is exactly like mine.
Thanks for all advice! :)
Damon329
new york
My 07 did the same thing after i removed every wire individually from the cluster pin plug. I was having an issue where the chime was intermittent when wiggling the connector to the cluster. When I removed each wire one at a time I opened up the prongs very carefully the reinstalled each one when I was finished. Unfortunately I reinstalled 1 of them into the wrong location on the plug. It gave me the pats warning. It was the transponder wire that I put into a blank spot by accident. That connector behind the cluster is prone to lose connection if there has been any movement to the cluster assy. If you remove each pin, make sure you take a picture of each wire location for future reference. A faulty connection will give you your exact symptom. The cluster is a module. A bad connection will give you many issues. Also my fuel gauge was always reading differently every time I started the vehicle. If I slammed my hand on top of the dash it would sometimes make the fuel needle re-adjust. All this was resolved after I opeded each wire end in that connection plug. There is a way to remove each wire individually from the connector. Be very careful not to break anything.
David Kuchler
Reno, NV
Did you ever, find the source of your problem?
1. pushing shift lever firmly to park position. seeing as how it would start in neutral, this is a possibility
2. battery connection, with no lights coming on, on the dash, would seem possible, its a dirty battery connection, or loose
I personally would guess its the shifter, not activating the switch to show its in park, but that doesn't explain no lights on dash, which would lean more to battery connection
Thunderbirdsport
Thunderbirdsport
Missouri
When I say no lights in the cluster, it's the warning lights that come on when the key is on but engine is off. Normally these would be on that instance but due to the condition, they don't come on.
Indeed, the battery connections were the first thing I checked, all are good, even the battery is newer...just a couple of years old.
I pulled the cluster out last night after work, wiggled the connector, unhooked it, wiggled the wires, put it all back in, still no a no start.
I had it Ford a week ago, the one time it did start since all this started happening, I should've left it there until it did the no start again and let them mess with it more.
I'm about 5 miles from them, thinking about having it towed (rather, rollback truck) back to them to see if they can find it.
Bryson A Martin
Mine recently did the no start bs while I was attempting to leave a bar. Yeah just my luck lol, but I had it towed home. Luckily I have a homeboy who does that for a living who lives near me so no charge. Anyways my terminals were so corroded that it couldn't get the connectors to generate the power to start it. I spent about 70 bucks at autozone for new terminal connectors, wire, butt connectors, and a heavy duty wire cutter. Had it all replaced and back up to beating down the block in about 2 hours. Took forever because of how much wire I had left because of the way best buy installed my sound system. Just a suggestion to check the battery terminals tho. Best of luck man.
BTW I have a 09 eddie bauer expy
Thunderbirdsport
Thunderbirdsport
Missouri
One thing I'm pretty on top of is the batt terminals and related connections LOL. I almost always put brass terminals on all of my rides too. Probably doesn't gain much, but I've never had a corrosion issue or a no-start to to bad connections after I've put the brass terminals on. I throw 'em on pos and neg posts both....
They've never corroded up and gotten ****** like lead terminals will do. Maybe it's me, maybe it's luck. Just one of those things that I do my way, and it works for me. Just a thought... ;)
Motorcity muscle
Motorcity
What??
Motorcity muscle
Motorcity
So it's fixed. It turned out to be the fuse connector in the SJB. The tech said if it starts doing it again, the SJB will need to be replaced...
I'm just happy it's mobile again.
Trying to figure out what the SJB connector is that fixed your problem. Was it the cluster connector or power supply?
Thunderbirdsport
Thunderbirdsport
Missouri
No clue. The quote of mine that you replied to was exactly how it was worded on the ticket, and what the tech told me when I picked it up after work LOL.
Honestly, I couldn't even tell ya where the SJB is on these damned things, so...
No members online now.
rockinghranch
