Captain Chairs to Bench Conversion
Jace
Utah
Hey all!
So we're looking at possibly reconfiguring our 2019 Limited Max's 2nd row with captain chairs to a bench setup in order to allow for some more seating. I swear I read about someone doing it or wanting to do it in the past, but I can't find anything definite in the search.
Has anyone done this that can share their experience, or anyone that has dug around that may know if it's possible or not?
Any help would be appreciated, thanks!
Calidad
I simply bought the bench 2nd row that converts to captains chairs. Maybe totaled Truck and buy the bench seat?
Jace
Jace
Utah
So you've done this, or did you start out with the bench and remove the center seat? I've seen pics of the center seat removal, and it looks like the floor goes down where the legs mount. I wonder if the floor pan is flat in the captain chair version, or filled with a spacer under the carpet to make the floor appear flat. I dunno if I can see ford using 2 separate floors or not? Thanks!
Utah
Jace- I'm in Utah too and looking to do the opposite, maybe we could collaborate (if you have a black interior)
Calidad
Started out with the bench, center flips down bingo captains chairs. Mounting points should be the same
LyoddChrissmiss
Cincinnati
I’ve got factory captain chairs, and my floor is flat as can be. No hump. Hope that helps
Jace
Jace
Utah
Thanks for confirming that, I hadn't pulled up my mats to double check.
I'm curious to know if Ford uses the same floor pan on both models, one of them having some sort of filler piece
Jace
Jace
Utah
49a1caffd6200b9c4d932e10e0d338e9.jpg 242a1d7d5d4573f447c26b8b0b4d354a.jpg 431ccb05826576f7a0b421c34199403d.jpg
I found these pics in another thread showing the center of the bench removed. These would be easily filled or covered with mats if you are going from bench to captains. I just wonder if these indents and bolt holes are present, but filled in/covered up in the captains chair models.
Jace
Jace
Utah
I may have to take you up on this! I should know which direction I'm heading here in a few weeks for sure. I'm going to try and see if I can figure out if I can bolt them in or not based off the images I posted above.
And to answer your question, I've got a 2019 Limited Max with a black leather interior. What is yours?
Jace
Jace
Utah
Makes sense.. so you did what I just posted pics of (maybe they are even your pics haha, if so thanks!) I'm curious on the mounting points.
So basically the only thing you lack is the arm rests.
