Wind Noise
lv2drive
PA, USA
omg winner day 2!
hussein - are you guys in dubai / uae?
having driven there myself a few times, i can now see how you could be driving the desert highways at 100+ consistently. y’all drive like maniacs over there, most of the highway nuts are in lambos. i’m just not so sure that i would do that sustained, at least not in one with a stock suspension.
i don’t think i would like to have to quickly avoid an obstacle at that speed.
side note @Hussein AlMoosawi
if you are in uae, have you run yours yet on the dunes alongside the land cruisers, & if so how does it compare?
DWs-TTEB
Evans, GA
My 5-Star tune set the speed limiter to 186 MPH on my 4Gen Expy. I haven’t gone over 101 MPH. I don’t see this boosted bus doing that well over 130 MPH. A crosswind and your done.
Iraq
100mph isn't that bad. I regularly cruise at 85 out in Wyoming. It's like a day in the Park. No issues. Heck the speedo on my 2014 goes up to 120.
I had a whistle from the driver window direction at about 60 on my 2003 for years, only in the summer. I tried taping the whole thing (window) off and no difference. Came back every summer, eventually went away once I accepted it and it didnt botha me.
I reached 100 mph with my explorer 93, it was solid like a rock with out any issues or noise.
and regarding the Expy 2018 its silent till 96 mph actually its silent more than most of the other brands.
Iraq
omg winner day 2!
Nope my friend I'm from Iraq, and its better there is no speed limits in Iraq.
Unfortunately I didn't run alongside land cruiser on the dunes.
Iraq
5 Stars tuner is not available in my country, I think i will try the HP tuner by just programing and removing the speed limits.
I hit the top speed with my expy 118 mph, its so stable and very comfort to drive the only thing I hate is that noise sound.
actually if the passenger did not look at the speed meter, he will not feel the speed and will not know that we are moving that fast.
cfldad
I almost lost my license to drive 20 years ago getting caught doing 92. Some states here will automatically take your license if you exceed the speed limit by too much.
I haven’t had my expedition over 85 yet. Agree it’s very smooth at speed.
DWs-TTEB
Evans, GA
ForScan let’s you change the speed limiter as well. Cheapest option (ForScan license = $10 USD | HS/MS-CAN OBDII reader $30 USD)
mx10166
Iowa
I think I found the culprit of my wind whistling noise. There is a small channel at the base of the mirror where it mounts to the doors right above the chrome strip that runs along the bottom of the windows. The channel is easiest to see from the front of the mirrors. The photos below are of the front side of the passenger's side mirror. I had some backer rod on hand, which is meant to fill expansion joints in concrete and is a dense foam material meant for outdoor use. I cut some small pieces and stuffed them into the channel at the base of the mirrors and it stops the wind from whistling in that channel. The area is really hard to see, so I'm not too worried about the gray foam against the black mirror base, but I'll keep my eye out for similar material that is black. It's a 5 minute fix for anyone that is tired of messing around with the dealer trying to solve the issue. Also, this fix isn't affected by folding the mirrors since this is the fixed base of the mirror.
Just purchased a 2020 Expedition Max Platinum and had the same issue. This fixed it! Would have never guessed this was the issue. Thanks!!!
Rednecked
Arizona
The driver side mirror on my 2019 has a slight whistle noise above 50 mph. I identified this by using the power fold feature at speed and the whist stops immediately when the mirror body moves.
I'll be mentioning it to the service department when I get my first service/ oil change here shortly.
Did you get this resolved?
gural
Poland / Europe
I have a noise issue also but a little bit diffrent
Speed i think does not metter (it happens with 60/ 80/or 50)
but if I go for longer period with same speed car starts to have some kind of noise like whirlwind somewhere under the car
If i take my leg from acceleration pedal or I put it harder (so basicly i change speed ever for 1 mile/hour) it disepares
If i go with it for longer time suddenly i got some kind of noise hit (like something would hit a car) and it also disepares
Any one got issue like this??
I think that somehow somewhere air is going under a car a is starts to twist there... but i do not know how to find a place how it goes....
I checked all the shileds and there are ok...
gural
Poland / Europe
I have a request to someone of You
Though I m from Europe and there are no Expeditions on the streets so I can not check it by my self
I still have the wind noise problem
but I after some checking i see that on the driver side , the fender shiled is diffrent then the one which is on pass side
Guard Front Splash - Ford (JL1Z-16103-D)​
Can any one make a photo of both side and insert them here
In my case on pass side it is a full shield and on the drive side it is a little bit cut
gural
Poland / Europe
In My car from driver side it looks like this that i can see the frame. From pass frame is covered by shiled. Can any one check if you Got the same
