I've never used a CAT scale, but would like to get real world numbers for my Expy/trailer set up. What is the procedure? Cost? Do it once, or more than once with WDH loaded/unloaded? Any way to weigh hitch weight there?
Looks like an F150 wont fit the bill from what I can see. Even though they have higher tow ratings, they're payload is pretty much the same as Expys. Got all excited when I saw some F150 people talking about a Heavy Duty Payload Package and 2200lb payloads, but turns out it's near impossible to get that short of fleet vehicles with no options.
Is there a way to shift cargo to the back of the travel trailer to lighten you tongue load? I suspect you probably have already done that. Even at the minimum 770 lbs of tongue weight you only have 630 lbs left of payload capacity which needs to include your hitch weight. I suspect you and the 3 boys average more than 157.5 pounds (not factoring in 50 - 100 lbs for the hitch). You didn't mention the Expy's GVWR, but it is probably a few hundred less than the sum of the axle weight ratings.
I'm still a bit befuddled on how I got to 1100lb tongue weight to begin with. From the factory stated tongue weight is 760. I've got one group 27 battery and only one of two 30gal propane tanks about 70% full. Nothing crazy in the front compartment. Two power cables, two water hoses, some leveling plastic blocks, set of anderson levelers. A plastic rug, small tool kit. Guess it all adds up quite fast.
That has GOT to tow noticeably better than before. Did you happen to measure your fender heights with the new setup? Depending on how close your front fender is to unloaded you might be able to even transfer a little more hitch weight.
You should be able to bring your front axle back to where you started, I think mine are around 35" high, so yes you are fine being 20lbs light but if you add more weight (to the front axle) and aren't lowering the front ride height at all you may find it rides even better.I did measure, it was spot on for front axle loaded and unloaded. Rear axle squatted an inch. It certainly felt better driving, but I only got on the highway for about 15 min and during that time I never had a large rig blow past me or encounter any strong cross winds to see how it'd react. I'm light by 20lbs in the front compared to Expy alone with no trailer. I imagine that's good enough?
I'll be curious to see how it will behave when I have my next trip with my 3 growing nephews. After loaded up it's quite the pain to think you might need that last extra washer on the WDH added but you're all ready to go.
Congrats on getting everything adjusted properly. It must be a relief knowing that that you won't have to swap trailers or tow vehicles. Your tongue is actually a bit light, as the correct measurement is in your second pass. The total load on the vehicle suspension increased by 700 lbs over the truck weight only. Your truck is 6420 and your trailer is 7440, so you'll want at least 750 on the tongue. Some of the trailer weight is on the rear axle with the WDH is hooked up, so you can't go solely by the tongue weight in your third pass. Adding 50 - 150lbs to the tongue will improve stability.
You can probably move some items from the rear storage back to front storage, or just load extra items in the front storage when you're traveling. Load range "E" tires help with stability as well and also provide improved puncture resistance. You shouldn't need to make any adjustments when traveling with your nephews. Just put their belongings in the front storage of the trailer. This will allocate most of the additional weight to the trailer axle so you don't exceed payload in the tow rig. Safe travels!
