Update all versions of Ford Sync 3 to the latest Sync 3.4
Moderator
Yeah, 2 20 is available now. If you have a 2020+ you can’t do it currently unless you are will to use a method still in development. If you have a 2019 or earlier you have do downgrade then load, but the CyanLabs installer does that for you if you input your current version correctly.
PS - I have used this Beta method to update my Maps but it was WAY slower than the downgrade method I used on others.
DWs-TTEB
Evans, GA
Upgraded to sync 21xx a couple of days ago. Snapper, less buggy with Waze and music apps work better. I don’t use XM so can’t speak to that issue posted above.
mpc11
MI
Thanks. 21020 definitely seems snappier. Other than info & data updates, any noticeable differences in the '20 maps to jump at this right away vs waiting for next longer drive?
Moderator
No speed or performance difference. I was on 21020 for a few weeks before doing the 2-20 Map update. Just 1.5 more recent Data. I honestly don’t use the built in Nav very often, but figured testing the install was good!
Gumby
Beaumont, Alberta
Just so I'm not messing up my head unit. To update the new map pack, I need to downgrade from 21xxx to 19xxx then once that's complete I need to go back to 21xxx with now the 20 map pack and it should be good?
Moderator
If you use the Cyanlabs installer, it will build you an installer that will do this, because you do not have a 2020. Because I have a 2020, I had to use a Beta method, because you cannot down grade a 2020, as it will brick the APIM.
Gumby
Beaumont, Alberta
I tried the automatic for downgrading and I must be messing it up? Grrr...
Moderator
Honestly haven’t messed with downgrades since I got the 2020’s, but I know others have had luck on other vehicles.
Probably some magic order.
techdude99
US
@Jon F mentioned an issue above...
@LokiWolf Thank you. My old eyes missed it.
@John F I have XM and just installed the latest Sync on my 2019. I'm also missing the artwork and I can't connect to any WiFi networks. I'll report back later tonight.
5280tunage
colorado
21020 took quite a long time to apply since I did the maps update as well, had to drive around for over 40min. But the update does seem a bit faster. Had lots of troubles getting the updater to download packages though, the would fail a ton, took at least 10 attempts for all of the packages to download successfully.
Definitely had to repair AAuto as well.
techdude99
US
My updates errored out on a 32gb usb drive and finally worked on a 64gb drive.
techdude99
US
Has anyone on the latest version performed a master reset due to some strange issues?
techdude99
US
I was trying to avoid a reset, but I'll try it tomorrow to see if that resolves the issues.
techdude99
US
Master Reset did not bring back album art.
I was able to connect to my cell phone hot spot but not my home network with a "...Sync unable to connect...," to my WAP. Very strange...
Tried rebooting several times. No impact. I re-ran the install again. Still no install errors. Same result.
Moderator
I am wondering if it is the APIM version?
Are you forcing WPA2 or WPA3 on your AP? Have you got 2.4 turned off?
techdude99
US
I'm forcing WPA2-AES with 2.4 and 5Ghz enabled. How do I view the APIM version? Is the Ford only 2.4Ghz?
