Update all versions of Ford Sync 3 to the latest Sync 3.4
LokiWolf
Super Moderator
Super Moderator
Richmond VA
Yeah, 2 20 is available now. If you have a 2020+ you can’t do it currently unless you are will to use a method still in development. If you have a 2019 or earlier you have do downgrade then load, but the CyanLabs installer does that for you if you input your current version correctly.
PS - I have used this Beta method to update my Maps but it was WAY slower than the downgrade method I used on others.
DWs-TTEB
Evans, GA
Upgraded to sync 21xx a couple of days ago. Snapper, less buggy with Waze and music apps work better. I don’t use XM so can’t speak to that issue posted above.
mpc11
MI
Thanks. 21020 definitely seems snappier. Other than info & data updates, any noticeable differences in the '20 maps to jump at this right away vs waiting for next longer drive?
LokiWolf
Super Moderator
Super Moderator
Richmond VA
No speed or performance difference. I was on 21020 for a few weeks before doing the 2-20 Map update. Just 1.5 more recent Data. I honestly don’t use the built in Nav very often, but figured testing the install was good!
Gumby
Beaumont, Alberta
Just so I'm not messing up my head unit. To update the new map pack, I need to downgrade from 21xxx to 19xxx then once that's complete I need to go back to 21xxx with now the 20 map pack and it should be good?
LokiWolf
Super Moderator
Super Moderator
Richmond VA
If you use the Cyanlabs installer, it will build you an installer that will do this, because you do not have a 2020. Because I have a 2020, I had to use a Beta method, because you cannot down grade a 2020, as it will brick the APIM.
Gumby
Beaumont, Alberta
I tried the automatic for downgrading and I must be messing it up? Grrr...
LokiWolf
Super Moderator
Super Moderator
Richmond VA
Honestly haven’t messed with downgrades since I got the 2020’s, but I know others have had luck on other vehicles.
Probably some magic order.
slyce8311
