Program idle RPM
getdealtwith
US
Hi,
Does anyone know if it's possible to set a different idle speed in the PCM with Forscan? If yes, how?
If not in Forscan, how about with the dealer software?
I've given up on finding a cure for the slight erratic idle shake I've been chasing (new OEM plugs coils, PCV valve, new IAC, clean EGR, motor mounts new, new hoses, no codes, no leaks found w smoke) and at 750, the motor runs smooth.
Thx
Trainmaster
Old School Member
Rockaway Beach, NY
No idea what year you're talking about, but using a good diagnostic program should tell you where the miss is. My bet is a bad (new) coil or plug.
Not sure about changing the idle speed. Maybe someone else knows.
G
getdealtwith
US
It's an '04, 5.4. I just bought a new scanner with mode 6 capability and will try that, but am still curious about manipulating the IAC.
riphip
Memphis, TN.
Were you able to check the vacuum hosing behind the battery?
Rockauto Vacuum Assemblies for 2004/5.4
G
getdealtwith
US
Yes. In my quest, I replaced basically every vacuum hose, including the ones you can't get to without the intake manifold out, when that was replaced.
