What to look for when buying a gen3 expy
brcknrdg Rob
Ventura Ca
I bought my 2008 with 125k miles on it and when I test drove it the driver window didn't work but the guy had it fixed when i bought it. After a few months the driver seat started catching or clicking like missing teeth or jumping, as mentioned above, but only in one spot. I pulled the seat at looked around under there around the track but I couldn't find anything so since we didn't move the seat much we just ignored it. No other issues until about 160k it would randomly lose alot of power and hesitate really bad and threw a bunch of codes but I ended up deciding on a tune up and the plugs didn't have any point left so that explained it and I changed the coils too just in case. Off and on, usually only while backing a small trailer, the cam phaser/s would clatter really loud and I would stop, put it in park and shut it off but it always cleared up when I restarted it. It's got over 200k on it and we are going to go ahead and change those just so it doesnt get worse. The passenger front window quit working around 200k. I changed one rear strut a few years ago and the other rear strut last year. Oh I used to go through brake light bulbs every few months so I switched to led and never replaced another one. Over all after putting 100k on it myself it has done extremely well. I have no complaints other than the hump in the hood catches the sun sometimes and glares the driver. Oh and the info center can be hard to see with that out dated green lighting. Excellent vehicle over all
This sounds like our 2009 XLT, the cable on the driver side window bound and broke at the pulley.No problem with brake lights. Driver side seat control stopped working due to the switch contacts being worn down(we use it a lot), same problem when backing up. Lost the water pump at 150,000. Blend motor actuator wore out. Im chasing the misfire but think it is only back until I get OEM replacements for the crappy afterparket ones I bought. Over all at 181000 this thing has taken care of us even if the nagevator lags on her maintenence before I remind her.
Hulkster
The colony, tx
This is like all of us. The window issue can be temporarily fixed with silicone spray. The brake bulbs are moisture or water getting into the lamps but yes led fixes that. Check your two upper vacuum hoses to see if they are pinched together and swap with some hoses. I did the high pressure oil pump at 175,000 and going strong. I have the seat skipping teeth issue but not sure if there is a fix other than replacing and thats not guaranteeing anything. Also check the spark plugs. I drive 2008 Ford Expedition Limited rear wheel 190,000
willymutt
Freeman, SD
We are looking at updating our 2011 Limited EL with a 2015-17. Our 11 has the rear tailgate pealing, electric running boards not working and rust on the rocker panels. Are there things to look out for on the 15-17 that are similar? Did they fix the pealing paint issue? Are there other common issues to be aware of and look for in the newer ones?
I've done the cam phaser lockouts on the 11 and put a 5* tune on. Would look at a 5* for the new one also.
Al Steel
Had an 08 Expy Limited. Picked it up with 14 miles on the clock, drove til 148,000 when a run in with a guard rail secondary to a deer strike ended it's reign. I had a love-hate relationship with it but had I to do it all over again and buy a used one of the same model, here is what I would look out for. I'm not talking about the usual used car/truck wear item stuff, these are issues I ran into that are specific to this truck. I experienced almost all of these issues and they can be big $$$ to fix. Thank GOD I got the warranty...
- Spark Plugs, spark plugs, spark plugs! - Let me say this from the outset. Like Bigfoot and the Chupacabra there is no such thing as a 100K mile plug. That's for 1 owner soccer Mom's that can't be bothered for their vehicle to be down for 3 hours once a year for routine maintenance. In the Ford 3V engine of this model year the 100K mile plug was a disaster. Check the maintenance records and if you don't see a spark plug change in the last 50K miles, consider looking elsewhere. You could be in for a $700-$1000 head/cylinder repair on the next plug change.
- End play in the crankshaft - This spells DEATH for your engine and a $7-8K (!!) repair if you don't have a warranty. Some motors in the 07-08 MY were defective in the assembly and didn't mate up perfectly with the transmission. The result, the crankshaft was allowed to move laterally mere thousands of an inch.. but that's enough to kill your engine around 50-70K miles. Despite religious oil changes and maintenance. The symptoms are subtle at first, slightly rough idle that resembles dirty injectors, minor spark, or fuel delivery. Then progresses to rough idle and eventually the engine will stall inexplicably and won't start until it cools. Then will restart and run for a bit but then stall. Eventually it won't start at all. So... what to look out for, check for signs of small metal shavings in oil.. I mean SMALL.. like metal powder. Of course it could also be like mine and the entire crankshaft seal plate was worn paper thin, cracked off and in the bottom of the oil pan too. :mad: If you see ANY evidence of this or strange running behavior as described, RUN AWAY!
- 4WD Wheel Slippage - In tight turns my 4WD would "slip". The front would buck hard enough to be a concern and it wasn't the wheels rubbing. I was told this was "normal" by the dealer, but I think he may have been avoiding another repair on a vehicle that he had already spent THOUSANDS on warranty work. Admittedly, I didn't use the 4WD enough in conditions where this happened a lot, but I never recalled it doing that during the first few years. May be an area to check because most owners of these vehicles rarely engage the 4WD. I would use mine as often as I could but make sure it's working correctly and shifts into all modes.
- Automatic running boards - The person that designed these deserves his own special place in Hell. It's absolutely the worst design EVER with the motor being integrated directly into the running board and placed in a high exposure location, unsealed, right under the damn vehicle. I constantly complained about those things, mostly because the awkward opening height was designed for Moms in heels and they opened so slowly that I was forever cracking my shins on them. Likewise if you were in deep snow, mud, sand, anything that isn't a grocery store parking lot, they would half deploy leaving you to search the poorly designed menu system to shut them off so you could exit the cab. NEVER liked them and this progressed straight to HATRED once they stopped working. As expected, 8 years of direct exposure to rain, salt, dirt, sand, snow, etc and the motors failed. I tried to limp them along by squirting in lubes, graphite, etc. Even pulled the motors apart and cleaned the windings. But no amount of care and maintenance could compensate for a truly terrible design and they eventually quit. If you want to replace them expect to shell out $1200 EACH for the integrated motor/running board combo... and that's if you like unpainted primer black. Tack on another $500-800 for paint and install. Don't even think about claiming these on the warranty either. I tried when one failed at 93K and 2 stealerships outright refused to cover them. Expect unavoidable problems with these at 100K+.. sorry... they just suck.
- DVD/CD Changer-Player - Whoever made these for Ford should also be waterboarded. Replaced 3 (yes 3) under the factory warranty. Plus it's nearly impossible to figure out how to navigate the awkward combination of controls and menus to get it working fully. Maybe your average teen could figure them out, but for me, I gave up after 2 hours with the manual on a 2 hour drive and just faded the sound to the back so my girls could watch Thumbelina for the 35th time. Watch for this to eventually fail or just not work. If you just HAVE to have the factory model of this POS so your kids can watch Little Mermaid on a screen slightly larger than the average cell phone, look to shell out $800+ bucks.. about the cost of 2 iPads.
- Corrosion on the lift gate - What is it about lift gates and Ford? You would think that the company that LITERALLY started the vehicle revolution would be able to get something as simple as a rear liftgate correct (see also Ford Explorer lift gate cracks). Alas, it's not to be. The aluminum liftgate on almost every single one of these vehicles shows some signs of corrosion from minor paint bubbling to large patches of rough white powder coated exposed metal. Mine was somewhere in between starting at at 90K miles. Despite "corrosion" being listed in the warranty (100K miles / 7 years), the dealership and Ford MoCo outright refused to cover it. If you find one without this "feature", count yourself blessed.
- Frame rust-through - Now I'm not talking about a little or even a lot of surface rust here, but it seems that the frames on these vehicles are prone to SEVERE car cancer especially in northern climes where state road crews aren't afraid to use rock salt. Maybe it's faulty undercoating or inferior (cheap) metal but it can be BAD. Take a hammer on your test drive and really wrap on the frame in spots. Pay very close attention to the rear near the sway bar/swing arms. Look for cover-up repairs or freshly painted sections. If you hit a dull spot or the hammer drives right through the frame... that's a hard "NO". Unlike the good ol' days, most welding shops wont touch a vehicle frame with a 10 foot pole due to liability concerns. If you are handy with a torch then you can weigh your options but you could be looking at a total loss. Donor frames, if you can find one, go for $3k, and that's before you even start the laborious process of swapping the entire vehicle over.
- Seat Heating Unit - If equipped, this can also be trouble. Mine went out with no warning at 76K miles with a very nasty acrid electric burning smell. So bad I pulled over and checked to make sure the dash hadn't caught fire. It didn't but after that smell, neither driver or passenger side worked. Another warranty repair that would have cost $1200. If you find one with a heated seat module that doesn't work then you could be shelling out some green or just get a $30 seat cover.
- Honorable Mention - Window Regulators - Why, why, why, in a $55K vehicle would something a SIMPLE as a window regulator be so poorly constructed that they would almost ALL fail before 100K?? 3 of mine did, 2 under warranty and the other, luckily my brother-in-law had a shop and got me the parts for his cost. Otherwise, look to spend $350+ on this common failure item. Listen for rattle inside the door when you close it and slow raising window. One is sign that the plastic tabs (yes) that hold the window in place have failed and your window will soon drop straight into the door panel, the other means that your motor is giving out. Either one will cost the same, unless the window breaks in the process.
- OH almost forgot... Poor Door Drainage. I began to notice a "sloshing" noise inside my door panels. A little investigation and the undersized drain holes at the bottom of the door panels seemed unusally prone to get clogged with dirt and debris. Once discovered it became part of my regular cleaning routine to stick a plastic knife or other non-metal probe up in the drain holes to make sure they ran free. This is probably the reason why I see so many of these with lower door panel rust.
This is not my opinion. I experienced all of these items in my 10 years of ownership. Keep in mind that I buy my cars for the long haul (usually not selling until 150K+ miles). In all my vehicles this one was one of my most expensive purchases and would have had the highest TCO of them all (by far) had I not gotten the warranty. Without the warranty, I probably would have lit it on fire around year 5. Not that I didn't enjoy the vehicle, it was a great car for the family. But the fact that so many very expensive things went wrong with a vehicle through poor design/craftsmanship that I had NEVER experienced before was very disappointing. All this in a truck that's supposed to be "built Ford TOUGH!", lol! the Ford emblem faded out to illegible by 80K.
Oh.. I did forget.. Air Ride Suspension - This goes bad too but I was lucky enough to be spared the out of warranty repair because the vehicle was totaled just as it started to go out. I'd stay away from models with this feature unless it's been recently fixed.
BlueStangGT
Oklahoma
I've not read through the entire thread so forgive me if this has been posted previously but as I shopped for my '14 I discovered that if you buy a Ford vehicle that had previously been purchased as CPO, the CPO Warranty follows the vehicle, not the purchaser.
PapaGegs
Indiana
My '13 has the hesitation/missing as well. Saving up for the plugs/coil packs route. 218,000 mi.
jimz
florida
I replaced fuel filter, drove out old gas, put in water remover and filled tank with new gas. Runs good now and only new part was the fuel filter.
RobK
Just got my '17 xlt back from the dealer. This time it was the rear main seal leaking oil and luckily I have 200 miles before I hit 60k on the odometer. Last summer they replaced the front engine seal, intake manifold seal and vacuum pump seal, as they were all leaking oil. Since my power train warranty is about to expire, I'm not sure if I'm keeping this thing or not.
vincentrose
Kershaw, SC
Got my 2014 Expy Limited (with 301A Package) last August $16,000, here are the "bugs" I had to work out
A/C Blower cutting off - Resistor and plug burnt out - $100
Plastic Drivers seat trim was broken - $250
Misfiring when punching it - worn out spark plugs - $90
Heated/Cooled Seat Filters - $30
Additional Ignition Key - $165
Serpentine Belt - $40
Navigation System Upgrade - $150, (probably unnecessary)
Front parking sensor - $60
Rear Brakes - $310
Idler Fan belt pulleys & Tensoner - $150
tkdgirl4
Hi all!
So glad I found this forum/thread. I'm currently looking at a used Gen 3 EL Limited/Platinum (I tow a TT that's 5,500lbs loaded). Reading about some of the things to look for has been enlightening! I'm hoping to look at a 2012 EL Limited with 123k miles. CarFax said its had 5 owners and originated in Ontario, Canada. Other than looking at the underside, what other things should I look for? Are 5 owners too many?
Josh Hagg
5 months ago I grabbed an '11 Expedition EL Limited. I'm not sure what package I have, could someone tell me how to figure that out? 1 owner here in FL, his title said he bought with 5 miles on it.
It had 144k mi, looks nice, and at the low low price of $3400 I felt I couldn't pass it up. Knowing it had the cam phaser problem, my mechanic took care of that for a little under $2k and I still feel I'm well in the green on this for some upcoming repairs I need to take care of. It had new tires, and the moonroof mechanism was replaced on it under warranty, so it worked. kbb private party price was $11-14k
What I've found was wrong with it when I bought it or have gone wrong since:
Real things -
-cam phaser
-Drivers door lock actuator not functioning ($16 part and my mechanic slipped it in while doing the phaser cause I had trouble getting to it)
-lack of power between 1-2 and when going hard and downshifting from 3-2. Mechanic says no codes, everything is fine. (gonna try a few things I saw in this thread)
-Brake sensor triggers a lot of lights, ABS, Traction Control, AdvanceTrac message on the dash. Brakes are all working fine. Mechanic says we just need to replace the sensor. He knows which one it is, I don't... so I'm waiting.
-Passenger side manifold gasket (mechanic says $500, but I found the manifold, gasket and bolts for $65-and think I can do it myself)
-ac drain leak... this one strikes me close to the heart. started about a month ago... leaking into the floor boards. It's not clogged, it'll drip slow out of the drain, but the water pours into the floorboard... mechanic says have to replace that whole unit... I knew it already cause I'd googled it but was hoping he had another fix. $2k the entire dash has to come out. Lots of labor and a $400 part
Trivial things or just reg maint-
-Paint bubbling liftgate and hood
-paint scuff on rear bumper
-3 small dents (altogether I'm not fancy I don't give a shi about these first three)
-Drivers door window is slow to roll up
-moonroof leak (it was just a clogged drain, easy fix with an airhose)
-rear doors slosh after rain with the water getting stuck in them (pull the weather stripping out a bit so it drains)
-rear window defrost does not work
-drivers heated seat does not heat the butt as well as the back
-drivers seat plastic trim pops off (drill + black zip ties = done)
-chrome shift knob trim is loose (3 of the four anchor points are broke, a little super glue when I get around to it will fix)
-center console arm rest, the "button" where it touches the base is broke off (a stack of 3 quarters is just the right size to fit this perfectly, will eventually super glue these too)
-1 key has some intermittent issue that will trigger the anti theft when trying to start the vehicle. 1/100 times. But takes about 5-15 minutes to clear up. Actually shut off the vehicle while I was driving it once. I do not use that key anymore.
-AC Blower doesn't always blow (loose wire under the passenger dash, jiggle it to make it work)
-spark plugs and boots(did these myself with no problem, just make sure you have a good air wand to clean everything out, and do it right, didn't do the coilpacks because other forums said they were fine, no idea why they recommended the boots, but they were cheap so w/e)
-air filter (5 minutes)
-sunglasses holder "hinge" is cracked so it doesn't fit right (I'll pull this down some day and superglue it back together eventually)
-second row latch trim piece has a broken tab. (gonna glue it)
-oil change
-brake fluid change (still haven't done this)
Things I love about it: Overall condition is good, no cracked leather, the body is in good shape, paint overall looks nice, everything is automatic, windshield wipers, lights, powered folding mirrors (the drivers side one has some automatic tint too), automatic running boards. I like the powered liftgate, turn signals on the mirrors, heated and cooled seats, power rear vent pop out windows, all the cupholders, there's one in each door, plus 2 for the front seats, 2 more for the second row and I think 2 on each side of the third row. Power ports... there's 4 12v dc ports. 2 in the dash, 1 in the back of the center console for the second row and 1 in the back. It has the nice navigation package and HD radio, the dvd players in the headrests for the kids. the space with the third row is amazing, plus the lay flat in cargo mode for when I'm hauling lots of stuff, that's what had me looking at the nav or expy over tahoe or anything else in the first place. I grabbed some cheap brand new weathertech floormats off fb marketplace and that's been good, but I still need one for the third row. backup camera is great (my first car with it). I wanted bench 2nd row for the extra seat. I've had 8 people in it. It won't be the last time that happens. The EL is great because I can have stuff loaded in the back while everyone is still sitting comfortably in the second and third row and grandma can ride with us without having to move all sorts of things around. The whole thing is super clean too. No scrapes or scratches. No fading. Carpet was great even though I covered it with the weathertechs. It doesn't look like a ten year old truck.
Things I would love to know wtf I'm doing with it...
-why is there a clip attachment thing in the center console? What was supposed to be clipped into it?
-I can't figure out how to get the dvd players to play through the speakers wirelessly and my audio ports or cables are finnicky and don't work 100% of the time. my remote will work on one of the dvd players, but I can't change the fm station on it and I need to because there is a local station on the default, the kids wear headphones... but I like singing to the disney songs too and I don't like to mess with the cable while driving.
-how do i upgrade the OS on the stereo? it has sync, but I've tried downloading the package from the ford website and following the instructions, but it won't read the file on the USB drive (and I'm a tech so... wtf?)
-rear view mirror is supposed to be the automatic tint adjustment thing but I don't think it's working.
Things I don't like:
-controlling the odometer stuff with buttons on the dash. put em on the steering wheel, wtf.
-garage door opener. this thing is a POS. it works kinda. I just use my phone "hey google, close my garage"
-the slippery dash storage, everything slides out of this. recommendations?
-the silicone cup liners, the liners come out when my wife pulls her drinks out. recommendations?
-window tint: I'll be tinting the windows soon. Going to go darker on the back, probably 10-15%... I'm guessing they are about 25% now. The fronts have nothing, I'll match the front sides to the back and tint the windshield to about 35%. Yes I'm legal, I have a permit for it, and yes I've done it on other cars... my last car was 45% on the windshield and no problems at all, but I do want it a bit darker. Going with ceramic on the sides and back to keep out the heat, probably just colored on the windshield so i don't risk the haze.
-rust... not that it's bad. but like my 04 crv had no rust and came from iowa before getting to FL. this expy has been FL it's whole life and the wiper arms have rust, under is surface rust... I just wasn't expecting that and seems like Ford went poor quality here.
-my drivers window has a creak. I can't figure out how to get it to stop. silicone spray is not doing it. It might not be the window and it's the trim but stops when I push on the window. I have no idea, but it's annoying
-glare: I cannot tell you how many times those chrome trim pieces around the shifter and the cup holders cause me momentary blindness
Oh and obviously an expy does not quite have the turn radius that my dumb little CRV does, but it seems even worse than what my 99 Tahoe was.
Machete
My Rig. 2000 EB 4x4 5.4L
Illinois
Hi all!
I suggest you think twice or at least be super vigilant on that Canadian Expy. Rust, emissions, it’s a northern car. Did I mention rust?
Goofy173
Ky
Never ever get a 5.4 3 valve engine! Soured a life-long Ford fan (since 79)
p38fln
It’s the 2004 to 2008 that suck. 2008+ are generally ok, but 2004 to October 2008 every single one had those horrific multiple piece spark plugs
p38fln
Every single one of these that I’ve ever seen has rusty rocker panels, even vehicles that are absolutely spotless otherwise. It’s the sunroof drains. Some freaking idiot at Ford thought draining them into the rocker panels was the best idea ever (I mean it’s a great idea if you want to force the cars to rust out) instead of two inches to the side, where they could safely drain straight onto the ground
sjwelds
Kansas
Sunroof drains don't have that much to do with it. My 2012 has rusty rockers and no sunroof.
No members online now.
Landsbutter
