2020 Expy Limited: missed shifts
Jerald Cook
Kansas City
I've encountered similar situations going up or down hills resulting a really harsh SLAM. I've complained about it on several service visits to the dealer and have gotten nowhere.
I've recently started having the same issue, on a fairly repeatable basis. When going slightly down hill and coasting, around 50 mph, I'll get an extremely harsh clunk when the transmission downshifts from 10 to 8. The harsh cluck also happens on occasion after starting the car and going from park to drive. I'm planning on setting up a GoPro to try to and capture a few incidents to share with the dealer.
Sounds like a few people are having this issue so hopefully Ford can diagnose the issue and implement a fix.
Kahuna
Kahuna
San Diego
Boy you are describing my situation exactly. Also going from 4-3 I get the same clunk.
Pretty sad that Ford put out a transmission or controller that is this flawed.
Two calls to Ford service and no call backs yet - to status what Ford has advised them to do for me :(
Kahuna
Kahuna
San Diego
Update;
Car has been with the dealer now for two weeks. Dealer unable to download firmware from Ford. They have a trouble ticket in with no response from Ford for days.
I just opened a Buyback application with Ford. They immediately interviewed the service rep to get all the repair records and info. He thinks this may help to put pressure on Ford to respond to the ticket. Ford claims I’ll hear back from them in 5 days to see if they accept the application. Then I guess the next step is an offer. We paid 82k for this (limited/Stealth package 4x and tow package)
It’s got 27k on it so there will be a discount on the buyback offer. If anyone has advise here I’m all ears :)
Dealer apparently thinks this is a software and not a hardware problem. I’m not convinced.
We’d rather have this car fixed then go through a buyback scenario. Cash in hand won’t help me if there’s no cars in stock. The dealer will put an order in for me when they hear the application was approved. Just get the process going in case they can’t fix this car.
We are taking ownership of a new airstream 25’ International right after Xmas. With no TV this won’t be fun :(
The Expedition is really our only option in this class to tow 7300 lbs.
Oh well the drama continues….
JakeInTexas
Mansfield
Mine just did the same thing kinda. At WOT @40/80mph its trying to shift into park. You can hear the parking claw engaging and everything. After 2 weeks of looking into it they are putting in a new separator plate on the main control valve?! Im still under full warranty. We will see if this is truly the fix....
Kahuna
Kahuna
San Diego
Boy that’s even a scarier situation than mine! Trying to shift into park is a transmission worse nightmare.
Just heard today that Ford wants to replace my transmission and cooler. That will take well into January before the stars line up to get the work done.
In the meantime there might be a buyback offer.
They have to fix this one way or the other - if they are going to resell it.
ROBERT BONNER
Denver, NC
I'm X-Ford with some contacts still inside. My '20 does the same thing, seemingly randomly. The guys I talk to inside Ford claim that all of the 10 speeds have the potential to do it in F's and Expeditions. They claim it is the result of an overly aggressive use of the Torque Converter Clutch to improve fuel economy. The shift strategy is to keep the Torque Converter locked for nearly all conditions outside of shifting. They describe it as a long shift event caused by throttle position changes and/or load changes during a shift event that cause the computer to change it's mind on what gear to go for mid shift causing the shift even to go long. The torque converter clutch then engages before the shift is entirely complete causing what they call a "slam-bang". Originally they thought that the events were rare enough to ignore; but, as we all know, it's causing real customer concerns. They're working on software fix(s) now.
I told them that I don't believe there is anyway that they designed everything else downstream of the Torque Converter to be able to handle more than a few dozen of those events without causing more problems. Just saying.
Kahuna
Kahuna
San Diego
Man I’m so so grateful for your input here and education.
“It all makes sense now”
So given your intel I’m thinking that even if they replace the transmission the software is really the issue here. The transmission will start to fail again until that software is updated.
Thanks for your input! I’ve got one more question for you that I’ll direct privately…
udntknw
Vail, AZ
Ok so now a couple of weeks later and Ford is still scratching their heads. Fortunately I now have real evidence (codes) that have left a trail of bread crumbs.
With previous issues it didn’t leave a wrench or error message/codes on the modules when read. The last two missed shifts resulted in me catching the “Shift fault” message before it disappeared and the service guy was able to use my vin number and see what the car reported as it happened. I included the screen shot below from his screen. But still no codes left in the modules to report a problem - strange.
Basically modules were not communicating which put the car in a “blind” kind of situation for the TCM. Not knowing how fast the car was going I guess.
Ford “mother ship” is apparently reviewing the situation and will advise the dealer. Probably throw parts at the problem.
Im hoping for a fix. Love the vehicle except for this crazy missed shift issue! Otherwise I’ll go down the path of the Calif Lemon Law.
Were they able to read those codes from the truck or through their OTA diag system?
aggiegrad05
North Texas
Given this 10 speed was developed jointly by Ford and GM, I wonder if it's affecting any of The General's models. If it's a software issue, and we know that Ford and GM each utilize their own software in the jointly developed hardware, my guess would be "no". But maybe someone has some intel that suggests otherwise?
Jerald Cook
Kansas City
When I took my 2020 in a few ago, I asked the service advisor this same question and his response was that the issue affected all the 10-speeds, even the GMs. His explanation of the issue was exactly the same as what Robert Bonner explained above, and said he himself was an unhappy 10-speed owner (and wouldn't buy another vehicle with the 10-speed until the issue was resolved), so I'm inclined to believe him.
r98exp1
