2019 4*4 Stealth shifting weirdness
Left Coast Geek
Mid Left Coast
I'm on an extended road trip in Mexico, towing a 4500 lb small fiberglass camp trailer. A bunch of times, when the truck is in tow/haul mode, and I give it some gas to pass someone basically nothing happens. It doesn't rev. Doesn't rev. It doesn't shift it. Just kind of putters along and then there's a delayed clunk shift and then it finally has some power. If I remember I've gotten to putting it in sport before I do a pass then it responds the way I expect.
Is this likely the firmware problem with delayed shifting and stuff in 4/5? I don't know what gear I'm in, because the 10 speed gear display went out the second week of this trip. I won't be home until early May, so I'm not going to try to bring it to a Ford shop here in Mexico because we have just too little time and are doing too much. We're never more than 4 days in the same city., and mostly we're staying in relatively rural areas. Fantastic caravan guided RV tour, the organized tours have been far more fun than I even expected them to be. Highlight next month will be the total solar eclipse in the Mazatlan area
Oh, this Expedition has the HD tow package, it was bundled with Stealth in 2019. By the way, I'm really glad I put 18 in wheels on this truck instead of the 22s it came with. Mexican highways and back roads are gnarly, the topes (speed bumps ) are vicious, and so are the potholes.
SyndicateZ
Mass
Mayne your tranny just needs to be "reset"
also
When my gear #'s displayed disappeard after a PCM flash i had to....
While the gear selector in in Drive "D" , push the "+" button located next to the gear rotary selector to show the gear #'s display back on your cluster.
Hellwig
notorious CDF drum issue, considering the model year of your vehicle. If parts are available, that job probably takes a couple of days in dealership.
Left Coast Geek
Left Coast Geek
Mid Left Coast
also
Doy, I feel like an idjot now. Yup, that's it. I've had the Expy since November and have driven it about 8000 miles and am still learning new stuff. Also, in D, the minus button let's you lock out 10, or 9,10, or 8,9,10...
tifanydire
