Who had success with dealership dealing with turbo rattle?
StephenPT
Portland, OR
Here's a pretty good video showing the root cause of the wastegate rattle. Seems to me a poor material selection by the turbo manufacturer. The pin on the wastegate rod is much harder than the actuator arm. If it was the other way around, you could just remove the double nut clamp, one of the nuts and add a new pin, instead of a whole new turbo. Better yet, they could have added an Oilite bushing to the actuator arm and with the impregnated lubrication in the bushing, it would last significantly longer.
Artie
Georgia
In the meantime, I’m going to buy an old LX470 as my daily driver while I build the resto-mod. (Actually going to look at an LX today)
Good luck on your 100 series search! If your not already on IH8MUD I’d suggest joining up, killer resource and forum for all things Land Cruiser.
I went with a 200 series.
NukeLife
Charlotte
That’s a beauty!
Yeah, I frequented IH8MUD before I bought the Expy. A 200 series LC was my first choice, before I discovered how awesome the 3rd row and cargo area was in the new Expy.
I’m not sure I can go backwards in space, now.
But I can buy this off a local one-owner for 15k cash. 148,000 miles
And use that as my daily. then work on building one of these for towing and road trips!
Team_Z
Wa
Ford doesn't care! They don't care about the waste gate, they don't care about the cam phasers, they flat out don't care about you. They have your money. Have a Ford day!
Unless things have changed with the 2021, 2022's, I laugh at all these guys buying new ones. Guess they don't read these threads, or hope theirs will be better. I just SMH.....no offense.
All new cars suck. My neighbor bought a new Yukon Denali, didn’t make it 1000 miles before needing an engine. All makes have their own issues. It’s not just a Ford issue. Go spend 90k+ on a Escalade or a GLS or Land Cruiser and see how much more those brands care. Toyota might care a little more but from my couple years at the brand, they were pretty much the same, don’t care until enough noise is made. Vehicles are man made, they will break, some sooner than others. I’ve had 10 ecoboost platinums the rest 5.0’s. Some had issues some didn’t. Hell I had 2 18’s at the same time and only 1 had issues and it was the one we drove less and had less modifications on it! If you base your vehicle purchase off of what you read on a forum, I’m sorry but that’s the dumbest thing you can do in my opinion.
Team_Z
Wa
That’s a beauty!
This was my demo while at Toyota for 2 years. This thing was a tank! I kept telling them I needed to lift it but corporate kept telling me no! You can see one of my F150’s in the back plastered in ice.
2018ExpyPlatinum
Arizona
Well, yes, forums are where we come to *****. Most forums would scare you aware from anything. Personally I'm a little worried about buying a BMW, but consumer reports just ranked them third (I think) in reliability. Surprised me! GMC was rated worse. I've never held CR in high regards. I digress.
My point here is....I have a two page letter from Ford telling me, net, net, they WILL NOT fix cam phaser issues after a certain date or mileage...PERIOD. They will do it once, IF AND ONLY IF, you do the customer satisfaction campaign by a certain date. Please go search for the thread for more details. That, sir, is a big FU from Ford. Like I said, it shows they don't care. It's a known issue, many here have had theirs fixed multiple times. Now Ford says too bad. It should probably be a recall. WHY would I buy another? If I was looking to buy an Expy, I'd be careful and do my research. Personally, I'm done with Ford. It would be the same if it were GMC, or MB or Ram.
Funny, you say Toyota will step up if noise is made. OK, good. How much noise is being made to Ford about cam phasers and waste gates, and now it sounds like trannies, and Ford isn't stepping up. They are walking away. YOU made MY point. Thanks.
Artie
Georgia
That’s a beauty!
We had originally considered the 209 series but the 3rd row was the deal breaker. Fast forward a couple years and we’re getting one anyway strictly as a adventure vehicle.
The Excursion is a killer platform if you can find one that’s still stock and not worn out. They are out there, though.
Artie
Georgia
That’s a beauty!
I think most people don’t really realize what goes into the Land Cruiser platform. Over engineering on pretty much everything and built for 500k miles and 25 yr service life.
What's the other option? Buy a GM V8 and have the lifters take a shit on you and leave you stranded?
I don't think there's a clear and convincing better option for 1/2 ton based full size SUVs at the moment.
Can disable the AFM pre ‘21. The newer ones are a different nut though.
BMW2FORD
CT
You can, there's OBD plug ins like the below and a pulsar kit for 19 - 21's but in theory, if you buy the car new and disable them you have a chance. If already damaged from smacking around when they bleed down and pump up then the damage is done and just a matter of time the lifters will wear out even if kept disabled.
Team_Z
Wa
Almost Anything done at a Ford dealer has a 24/unlimited mileage warranty. If you’re needing cam phasers done that frequently then there is something else going on, more than likely dealer related not Ford. Ford will fix those issues even after they have sent out that letter, especially if you have had it done before. Working for Ford for almost 10 years I’ve seen them go way above and beyond for customers. Hell, I’ve seen Ford cover clutches on a GT350R. You make enough noise the right way and they will do what is right, most companies do. If you’re a jerk about things then you better believe the dealer will drag things out. Hell I had a H.O raptor engine put in my Platinum under warranty because the tech was on some shady. Then the back ordered head gaskets that they had my truck for 5-6 months. I kept my cool the entire time yes I was lucky enough to have several other vehicles to drive but they had also given me a loaner car. And after speaking to Ford customer service and being polite and them seeing how loyal I was to Ford they did the right thing. In my experience Ford has always done right by me, not always easy but in. The end they do. And no I hardly tel the dealers I go to that I was in the industry. Out the 10+ ecoboost that I’ve had that one was by far the worst. Was I done with Ford? Nope, Because I own other makes and models and have issues with them, on my MB that’s become a big pain in my ass and it’s a new 100K+ vehicle.
In all honesty where I feel Ford is making the mistake with these 3.5/5.0 cam phaser issues is by not requiring the vehicles to do Full Synthetic 5-7500 mile interval changes. But recommending 7500-10k changes on blended oil.
My customers that used FS oil and changed frequently never had the issue. The oil pickup screen gets clogged and starves the phasers from oil. Talk to a Ford master techs and a majority of them will agree that changing your oil more frequently will help prevent the issue.
2018ExpyPlatinum
Arizona
@Teamzambo ...OK, you win. I thought Ford did away with that repair warranty, and wasn't that if you PAID for the repair? Oh, right, folks here are having it done under warranty. I think that's called screwed. I know guys here have had cam phasers done numerous times, some at different dealers. All I know is what the letter says, and what has been explained and posted on here. The letter clearly states ONE TIME repair. There is even a discussion that the extended warranty many have paid for will NOT cover addition cam phaser repairs. Some have had the "customer satisfaction campaign" done and it caused more issues. IDK. Whatever. I still think it's a s@#% move that Ford won't do the right thing. You're a Ford guy, so like politics, nothing I say or do will change your mind.
Team_Z
Wa
I’m a car guy. I currently own 2 GM vehicles, 2 Ford’s, a new Toyota and a new MB. Looking for a special Nissan but might wait since used prices are still nuts. I get A plan pricing, if it wasn’t for that I probably would own more GMC’s or more German cars.
ygfvdrrtffy
Washington
according to this tech, the issue is a leak down resulting in oil starvation, NOT starvation from lack of flow. Apparently, there is a known fix of going from a three bolt to four bolt cam phgaser, but parts are on backorder and it's really expensive. video here https://www.youtube.com/watch?v=PZ7-eLebdPs
TheDoug
TheDoug
Mansfield, TX
Here go on week 2 of not having my expy, tech has been good on following up but they still have not diagnosed the turbo rattle.... sigh. Cam phaser and wheel hubs are on order though.
After watching the videos posted about phasers and turbos, it worries me about how long I am keeping this vehicle even though I love it.
5280tunage
colorado
First time Ford customer here. I'm sure you've read my posts but I'll briefly describe my experience, to refute your stance a bit. And I'll take into consideration you're clearly a Ford person in and out, including working for Ford. I have a pretty good dealer, granted in the last two years they were acquired, did what always happens and lost nearly all of their awesome techs, service writers, managers, etc, several times. But luckily, most of the replacements have been pretty easy to work with.
My issues with rattling wastegates started at around 7K miles on my brand new '19 plati. I took a huge leap of faith, did so much research prior to buying this, and spent way more on a vehicle than I would have ever considered doing. I bought this thing because of it's size, volume, towing, and the engine (power with economy). I came from 5 different Gen2 and Gen3 Hemi's that were pretty darn bulletproof, but definitely drank the petrol!
At 7K miles, I took it for the wastegate rattles, I had multiple videos, the F150 TSB, forum articles for similar noises, and found a perfect way to recreate the sound every time. Showed the service writers, the heavy tech, etc. they all agreed, it sound like crap. Then (given there were still expy's on the lot) we took a brand new '19 expy and ran them side by side, no rattles. Should be more than enough evidence of the issue. I even had audio of how loud it was while driving, echoing off of structures and re-entering the cabin.
They wrote it up, and submitted the repair requests to Ford. oh boy, it went downhill from there, and mind you, per your statement, at this point I was still very nice and pleasant, and patient. So Ford comes back with absurd options. First and foremost, they tell the dealer they won't even consider repairing the turbo's until I do the phaser repair. Mind you, we didn't have any phaser knocking, and this had nothing to do with cold/warm engine. So 90 days later, parts come in, vehicle is in the shop for over 4 days just for that, and you're tearing open a perfectly good engine at that point, for nothing, probably causing more issues than you're fixing. When I went to pick up the car, while in the service bay, I start it up, do the process, and voila, the rattle is still there, just as bad as ever!
So they contact Ford again. Ford tells them to do the F150 TSB piece that tries to replace the wastegate actuator arm, so 2 weeks later, parts are in, leave the vehicle for another 2 days, pick it up and voila, still rattling. The noise is inside the turbo itself, has nothing to do with the actuator arm (and the heavy tech showed me an email where he told Ford it wouldn't help). He was pissed for me at this point. So we start escalating, and Ford absolutely refuses to replace the turbos. I called Ford Customer care, and long story short, I spent hundreds of countless hours on the phone, over a period of 6 months, being told Ford reviewed the case and refused to do the turbos, citing it's not affecting performance or reliability. I refused to accept that. Two pieces of metal rattling like that will eventually wear down the weaker of the two, and then what, I'm stranded on the highway with two young kids? Not to mention, I didn't buy an $85K+ sticker vehicle for it to sound like a loose heatshield. They didn't care.
Ford Customer care was a crap show. They assigned a person from who knows what country to try and communicate with me, refused to let me speak with any of the "engineers", "techs", those making decisions. The case worker actually told me many times, there is no way to escalate further. And I literally had to argue over and over and over that no business has a single flat line of customer care, and that there must be a manager or supervisor I could speak to. In 4 months, I literally never got to speak to a supervisor, till finally about the 5th month, I got a supervisor. I was still pretty nice and patient, but not budging on my stance. Then, I got a call from the original case worker saying they are working on a buy back offer. I explained we hadn't even discussed that, and that to me, for a publicly traded company, I didn't understand how fiscally they could (and i own ford stock myself), justify a buy back instead of just fixing the turbos. Mind you, my dealer reps are pushing from their side as well.
It took just over 6 months of arguing for Ford to finally agree to replace the turbos. 3 more days without my vehicle, and yay! the rattle is gone! Sadly, about 10k miles later, I've heard it come back a few times, so it's clearly a terrible design and will happen again. My experience with Ford customer care was terrible. Just to give you an example of the opposite, about 10 years ago, I had one of the first Grand Cherokee's with a moon roof, and it rattled a lot. I went to the dealer probably 15 times over 2 years to get it checked, and jeep was very helpful in trying to figure it out. Daimler at the time actually flew 3 body techs out, from Detroit, to Denver, to do ride-along's and troubleshooting with me. They found the issue, simply a missing nut on the moonroof frame. It was a completely different experience, and they not only gave me a 125k mile full warranty, but they paid me back for the warranty I bought with the vehicle when I bought it new.
Ford offered me nothing for my time and troubles, other than 6 months of oil changes, seriously? My rig is doing pretty great right now, still have quality and fitment issues all over, but I love driving it. But I'm not sure I would ever buy or recommend buying a Ford any time soon. So as a Ford employee, who likely also relies on stock prices for retirement, ESPP, etc, you might understand why terrible customer care will continue to hurt a company and it's standing. it's one thing for example, for terrible customer care with consumer product companies like Dyson, Apple, etc. A $500-$1K investment on a consumable is vastly different from a nearly 6 figure product. Especially, with Ford (again it's Ford), getting up there in the same price ranges as Lexus, MB, BMW, Cadillac, etc, they need to step up in the customer care. I even wrote a letter to the "CEO" and got nothing, zero, zilch back!
Sorry for my rant, but I love an opportunity to actually tell a Ford employee a real customers experience, lord knows the customer care folks didn't care! And don't get me wrong, I get nothing is perfect, but the tolerances and apparent lack of pride from manufacturing is apparent. Just look at the folks on here who wait for months to buy a brand new rig and get it with body panels not aligned, parts missing, stuff screwed up from day one. I read where you said these are made by people, any more, larger and larger groups of those people are simply monitoring telemetry from robots and computers, not taking a wrench and turning a nut. I'm coming from a place of experience here, Toyota and Hyundai were customers of mine for years, and when I would tour their facilities, their tolerances were so much more strict that than these appear to be. it's frustrating, more could be done, but even when there are problems, the real measure of pride is how you handle the problem.
PhrogPilot
San Antonio
After problems with cam phasers, struts and shocks as well as weird transmission shifts on a 2018 and 2019 I have a GMC Yukon diesel on order. Probably going from the frying pan to the fire as the GMCs are apparently rated pretty low for quality too but I'm through with Fords for the near future. I've driven a bunch of Fords for years with no problems but the 2 $80K Expeditions I have owned have been nothing but problems - and between the two of them I don't even have 80,000 miles! NOT to mention that my rear driver's side door is badly misaligned, shouldn't happen with an expensive vehicle. Every time I see it in the rear view mirror I say, "no more Fords".
Artie
Georgia
Since this thread has morphed into a general cam phasers/ford and Lincoln/ dealer vent session I think this post is applicable. Here’s a picture of me today, reseating a small cooling hose that finally came off it’s fitting because the hose clamp was never returned to its normal position. It was likely from my cam phaser repair and the clamp had been in the wrong position for long enough to leave an indention. Simple fix on the side of the road but with my young kids and wife and camper in tow and being in the middle of no where this may have been the straw that broke the camels back. Calling service manager tomorrow, I’m not even sure how to start this conversation.
Thankfully we had our camper which had enough water to refill the cooling system. It ran hot but only briefly.
5280tunage
colorado
And thankfully you had a small ladder. These front end designs make it nearly impossible to reach most of the engine. Sorry for your roadside issues. Oh, and that thing in your wasteband doesn't look super comfy, where's the IWB holster? LOL, don't blame you though, I'm in the same boat!
NukeLife
Charlotte
Dayum.
That’s the kind of thing that will blow my relief valve.
If the tech working on my machine is in that much of a hurry that he isn’t carefully inspecting his assembly connections for engagement / alignment / tightness, then he has no appreciation for attention-to-detail.
So then what else has he screwed up that I can’t see.
Artie, you are clearly not afraid to jump in, get your hands dirty and git’er done. I consider basic mechanic skills / handyman skills an integral part of learning life-essential skills.
Seems like a dying breed in many parts of the land.
Pass it on to your kids, people. They will, one day, be grateful you did.
No members online now.
rockinghranch
