What is leaking?
Nytimes770
I usually park in the garage. Today I left it in concrete driveway during the day to find wet spots not dry up. I managed to take this picture without the car jacked up. It’s from under the hood on the passenger side near the tire. The big cloth plate you need to remove to get to drain plug I didn’t remove so I didn’t get to see the actual source of the leak. It happens to be dangling a bit or at least hanging a bit loosely. Wonder if this is normal or they didn’t screw’s everything back in. Anyhow any guesses on what’s happening? Is it a loose drain plug?
All of my oil change have been att the dealer.
What is that thing that says gas filled do not fill do not heat with the spring covering it? I see moisture on that as well in the photo.
Thanks.
N
Nytimes770
Ok googled the part number and the cylinder shaped thing is the shock absorber. If this is what’s leaking would it be covered under the 36/36k warranty?
DWs-TTEB
Evans, GA
That is a Front Strut & it appears to be leaking. It is a under warranty item. Depends on the Ford dealer from what I have read on here.
DWs-TTEB
Evans, GA
DWs-TTEB
Evans, GA
Squark
NC
I agree that it appears to be your strut that's leaking. It is covered by your 3/36k warranty.
N
Nytimes770
Aye caramba. Maybe I should consider myself lucky to have a minor leak so far. But Would I have to constantly keep an eye out on the other 3? I’m at 13k miles, 26 months in.
Deadman
Those are the base struts, they fail every 10-20K miles. Look for an aftermarket strut after the warranty expires.
ManUpOrShutUp
As others have said, the Ford shocks/struts are crap. I had 3 blow out on me in about 30k miles and ended up replacing with Bilsteins. No troubles since.
N
Nytimes770
Took it to the dealer. Although I think only one was leaking they replaced all four. Warranty runs out in 9 months. Hoping won’t have to replace them for a couple of years at least.
Those that got aftermarket installed around how much did you pay.
apex96
For parts and labor I’ll be in it for $1,500 to $1,600… for parts only it will be $580. Unfortunately I’m not at a point in life where I have the tools or room to complete the swap myself. I’m scheduled to have the swap completed in early April.
N
Nytimes770
Correction. The work order says they found a leak in all four.
duneslider
Utah
I am sure there are other options but the bilsteins are a good option and not too expensive. I have enjoyed mine quite a bit.
N
Nytimes770
Is the wear of these shock absorbers driven by miles only and not time? As in after replacing them if I just drive 5k miles over the next 5 years, they probably will not leak?
Bmac1955
Southern Cali
No guarantee on not leaking. Probably will at some point in time. Then just put the Bilsteins on it. I Did with 39k. Vehicle under 4 yrs old.
5280tunage
colorado
Quality is Job One.
:chewie:
Seriously, and it doesn't seem to be getting any better. My 2024 F150 Loaner just blew a shock, all over my garage floor with only 1200mi on it. Come on, that is downright absurd. Never been offroad, no towing, brand new. It's getting so bad it's stupid.
