Nytimes770
I usually park in the garage. Today I left it in concrete driveway during the day to find wet spots not dry up. I managed to take this picture without the car jacked up. It’s from under the hood on the passenger side near the tire. The big cloth plate you need to remove to get to drain plug I didn’t remove so I didn’t get to see the actual source of the leak. It happens to be dangling a bit or at least hanging a bit loosely. Wonder if this is normal or they didn’t screw’s everything back in. Anyhow any guesses on what’s happening? Is it a loose drain plug?
All of my oil change have been att the dealer.
What is that thing that says gas filled do not fill do not heat with the spring covering it? I see moisture on that as well in the photo.
Thanks.
Thanks.
