RCI Skid Plates
K
KFordEx8
SF Bay Area
Mine arrived in two boxes. The engine skid plate box is 42.8 lbs and the box with the tranny and t-case plates is 55.4 lbs.
They shipped quick.
K
KFordEx8
SF Bay Area
Had these installed on my 2019 Limited at a 4x4 place in Lakewood CO (RSG Offroad)..they removed the front air dam (thank goodness that ugly piece of plastic crap is gone!) and it basically bolted on EXCEPT for the connection between the front skid plate and the transfer case plate. There are no corresponding holes in the frame as there are on the F150 but they were able to drill a couple new holes in one of the plates and bolt them together. Looks great and no rattles or other problems. No issues with oil changes either. I bought the complete set except for the fuel tank protection. And yes - you will be really happy with this.
I think they sent me the wrong piece that goes under the steering rack. The one in your picture and on their website has a bend in it across the cutout. The one I got is flat and makes contact with the steering rack.
K
KFordEx8
SF Bay Area
I’m checking with RCI to see if they sent the wrong part or if I ordered the wrong thing.
Everything looks like it’s lining up well. I drilled a hole in the front bracket to mount it in that position since it looks like it lined up the best.
K
KFordEx8
SF Bay Area
Spoke to Tim at RCI. He thinks that the newer version may fit better. The second piece has the bend which should clear the steering unit.
He said the main difference is the bend and pre drilled hole locations.
They are going to exchange that piece.
5280tunage
colorado
yup, bend is critical. Interesting, I see some new slots in yours mine doesn't have. Nice to see them continuously improving these. I love them, get so many compliments at the dealer for their strength and design.
K
KFordEx8
SF Bay Area
I used some shock stem bushings to space that part down a little to clear the steering unit but it is making contact. Going to look for something that is not or less compressible.
For the transfer case plate, looks like this bent version won’t work.
0EC96D3E-4429-4DAD-A65D-B8743BF9D97F.jpegB0F8D40F-7B69-490A-9A52-2A2FFDC675D6.jpeg16DB55EF-7172-4524-ACB1-39071A53282E.jpegEA4C9C5F-4B27-499D-9134-1BB9C1DD477C.jpeg
K
KFordEx8
SF Bay Area
Looking good! Has to feel good having that project finished. Any noteworthy comments on the install and can you confirm the RCI package you ordered for any future orders?
I will add more details with pics completely done. There is still the T-case piece.
As of now, it is looking like the newest F150 kit would be the way to go mainly to have the piece that clears the steering rack.
Alwaysthinkin
Georgia
Will RCI just build some for the Expedition already so we can stop with the driveway fab to make things fit.....
I asked about that last year, including a group buy, and they were just too busy. Plus, don't think the numbers are there for Expeditions as opposed to the Ford truck line. Guess you could always ask again....
K
KFordEx8
SF Bay Area
Tim at RCI told me that they don’t have any Expeditions in their fleet R&D on.
okidoki
fort lauderdale
thanks for your info.
did you also bought the skid plate for the fuel tank or ain't that necessary because the full package already covers it? (as it isn't included in the f150 package I noticed)
5280tunage
colorado
Guys, I posted nearly two years ago about my experience with RCI. It's rock solid still to this day. Did I have to drill a couple holes, yes, but based on one of the diagrams they showed me on the F150's, even they have subtle changes between production runs, i.e. a quick nut hold missing, a bolt in a slightly different place, etc. If you want a very robust plate package that may require a few extra speed nuts and holes, this is your kit. It was very easy to install and still to this day works great.
the guys at RCI were very helpful but to one of your points, they don't have a test vehicle. For most people, this is a pretty easy install if you have a few tools and some drill bits. Now technically, if I didn't install the tcase plate, I wouldn't have had to drill any holes. I elected to for the front brackets just to add a little more rigidity and to make install a little stronger.
