2nd row Captain chairs to bench
kmart223
I have a 2020 max platinum with captains chairs, I’m going to be converting it to the bench. I know a few people have done this. I have everything I need minus the spacers, does anyone happen to know the part number for them? Thanks in advanced!
18MaxLimited
US
What spacers? I recently completed this on our Max platinum and the only thing I needed were additional front and rear seat bolts to secure the middle seat to the floor. Under the carpet, there was tape over the front and placeholder bolts at the rear, but they were not long enough to use with the seat installed.
No spacers needed... The slide action is a little tight but I chalk that up to having used a limited middle bench seat which may be wider than the Platinum middle bench seat since the Platinum chairs are noticeably wider. Can you clarify?
Bmanxx13
Arizona
I want to go from bench to captains chairs but it seems hard to find just the captains chairs… I have the black leather with heated seats.
K
kmart223
So I’m referring to another person that did this as well from another forum. See this link below
I have not begun to tackle this so I’m just going off what other have done. So you were able to simply cut the holes in the carpet and bolt the middle seat in?
I purchased a platinum middle seat so I’ll see if it’s any different.
K
kmart223
Also were you able to hook it up to the trunk fold down button?
18MaxLimited
US
Yes to just cutting the carpet. That's probably the only part of this job that's "point of no return"
I used the foam peice under the carpet as a stencil and marked my "cut here" holes with chalk.
No to connecting to trunk fold release. I was motivated to finish the job in under 2hrs and didn't have this part ready. It wasn't a priority for me but I may complete it later as needed.
18MaxLimited
US
You can just remove the center jump seat (four floor bolts) and you'll have captains but without the armrests. You'll need floor mats or a Navi center console to cover the holes leftover.
pmcrae
Hey! We just did this on our 21' xlt but we're having a hard time using the slide and tilt function because the seats are rubbing and getting caught. Any insight?
sharprd65
