2022 Expedition Brake Controller
murrdawg50
Where are you trying to mount it? This goes in the lower spot. The coin slot is designed for the Trailer control knob.
Actually, the coin slot is for the trailer brake controller according to the 21 f150 dash. The trailer control knob is about and it looks like they had a hole punch out of the dash to mount the trailer control knob.
mrmustang
Greenville, SC
Different than the Expedition vs the F150. I've attached a screen grab (my Expedition in shipping status)
The knob in the upper left hand side is for the trailer back up assist, while the slide bar below it is the actual electronic brake controller that fits in the lower slot just to the left of the temperature controls.
Bill
murrdawg50
Bill
The coin slot on my expedition is in the same place as the Trailer Brake Controller in the picture.
mrmustang
Greenville, SC
The coin slot on my expedition is in the same place and the Trailer Brake Controller in the picture.
On a 2022, correct, that is where it belongs if installed by the factory. There should actually be a plug wrapped up under the dash, behind the "coin slot" for the correct "Expedition style" brake controller. This was done as a cost savings for Ford, and a way for a dealer to easily "upsell" the controller unit
murrdawg50
I looked, no plug wrapped up that I could see
Grizguy
Erie pa
a few months back in N W PA. I was traveling east with hard GUSTING winds out of the south with drifting snow. I was driving normal 60 .. 65 on side road with my trailer following me. One of the gusts hit as I was going over an ICE patch. The trailer went full sideways.. So thankful I knew enough to hit the gas not the brakes.. I bit sketchy as I was already going faster than I prob should have.
murrdawg50
Unless you’re seeing something I’m not, all those cable run to the climate controls and infotainment system
Redwater
Manitoba
I discussed with technician at dealership. They confirmed with me no plug wrapped behind the coin spot. They said that hole is not fit TBC model number: JL3Z-19H332-AA.
They said TBC F150 2021 may be fit that hole. TBC part number: ML3Z-19H332-AA
Im still waiting update from Ford. Expedition Timberline is still new model.
Just in case, I plan to use Tekonsha Prodigy 902502 Trailer brake controller when I tow my trailer.
Thank you.
M Bennett
