DRSpiritUL
Yes it is. Thank you!That front axle rating seems to line up with a 2WD XLT on the spreadsheet. Is it a 2WD model?
It also looks like an error on the axle code. I believe 3L is the code for the ELSD, but the ELSD shouldn’t be available on a 2022 2wd.Yes it is. Thank you!
Was also looking that up as well and seems like they have used 3L for multiple different mostly were 3.73 and a couple that were 4.10, sometimes slip and in sometimes non-limited slip. Think Ford messed up big time on that one.It also looks like an error on the axle code. I believe 3L is the code for the ELSD, but the ELSD shouldn’t be available on a 2022 2wd.
It’s interesting 3L is a 3.73 electronic limited slip for the Expedition, and then for my 2023 F-150 L3 denotes the 3.31 electronic locking axle. Ford sure is confusing with their axle codes
Hi,
So I have read the thread to understand how payload changes with the specs of the car, but for the life of me, I cant determine why 2 cars that I am looking at have such different payload capacities. Both are 2024 XLT, with HD Trailer Tow Package, Captains Chairs, 4WD, and Pano sunroof.
Car 1 - 1405 lbs - Link to Listing
Car 2 - 1537 lbs - Link to Listing
Can anyone tell me why based on the the listings?
Hi,
However, if someone can help me with the below, it would be greatly appreciated. The reason I am asking this is, I am looking for an Expedition with at least 1500 payload capacity.
2023 Limited - 1649 lbs - window sticker
2024 XLT - 1405 lbs - window sticker
I would of thought the Limited being a higher trim and have more gadgets would reduce the payload capacity but clearly that is not the case. If anyone can tell me the reason behind the near 150lbs different, it would be greatly appreciated.
The dealer sais
"As for the difference in payload between the XLT you reached out on and the Limited’s I’ve sent your way, the Expedition Limited has a continuously Controlled Damper with Sport tuned suspension. This electronically controlled suspension gives us the improved payload capacity. "
Is this the CCD W/SUSP ROAD PREVIEW 1,245.00 I see in the window sticker of the Limited model?
