Expy Gator
Not happy with the body lean of my ‘22 Timberline - are the factory sway bars the same as the base models and what is current best alternative? Hellwig with some poly-urethane bushings?
exactly my thoughts. This is the reason they never offered these years prior...You bought the offroad focused Expedition, and you are upset it has body lean? You do realize upgrading to stiffer sway bars will negatively affect the off road performance right?
I totally agree - it really should have coilovers and sway bar disconnects - but seriously, when we are talking about off road I have a modified Jeep Rubicon and a Raptor so I‘m putting this in perspective. I run this more on road than either of my others so if I can improve upon its on road leaning it would make me happy.You bought the offroad focused Expedition, and you are upset it has body lean? You do realize upgrading to stiffer sway bars will negatively affect the off road performance right?
Get it. So hindsight 20/20, the Timberline wasn't the right choice. In that case Hellwig is your best choice.I totally agree - it really should have coilovers and sway bar disconnects - but seriously, when we are talking about off road I have a modified Jeep Rubicon and a Raptor so I‘m putting this in perspective. I run this more on road than either of my others so if I can improve upon its on road leaning it would make me happy.
In your opinion what would have been better for my needs? I wanted the HO 3.5.Get it. So hindsight 20/20, the Timberline wasn't the right choice. In that case Hellwig is your best choice.
If you weren't going off road, the SPP(Stealth Performance Pack) would have given you the HO, in a road/slightly more performance based option.In your opinion what would have been better for my needs? I wanted the HO 3.5.
I replaced the stock sway bars on my 2020 Limited Stealth (HD Towing) with Hellwig front and back and it made a huge improvement, especially when towing. Only issue, they are a little pricey.
It takes longer to grab the tools than it does to install it.Hi Maxie, did you replace the bars yourself? If you worked with a shop, would you please let me know how much you were charged for the labor? Thank you for your time.
Are you a Hellwig rep, or just chose to name your account that?Hi Maxie, did you replace the bars yourself? If you worked with a shop, would you please let me know how much you were charged for the labor? Thank you for your time.
Thanks!It takes longer to grab the tools than it does to install it.
It's just a nickname here. I have nothing to do with the manufacture.Are you a Hellwig rep, or just chose to name your account that?
The last thing I would want is 22" wheels - I do tow a trailer and wanted something that would be good in the sand off road but not like Jeep off roading. Really not many choices out there if you want a larger SUV, 8 passenger capacity and some off road capability. I looked at the Wagoneer, Tahoe, Land Rover and Sequoia but liked the Timberline better.Stealth Performance Package has the HO 3.5
I have a Timberline with 18" wheels - may go to 17" when I upgrade.You can change wheels and the spp wheels probably fetch decent money when new take offs.
