Spark plugs and coil packs 2017
zach1027
texas
What kind of spark plugs and coil packs are recommended and how much should I be looking price wise
Misfire in cylinder 4 might as well get them all done
Last time I checked, the list price per coil was about $95. The plugs are about $12-$15.
I would only replace the affected coil, unless all the coils are aftermarket ones.
Here is information about aftermarket coils: https://fordauthority.com/2022/12/ford-tech-says-aftermarket-ignition-coils-are-no-good-video/
Here is information about counterfeit plugs and coils: https://fordauthority.com/2022/10/ford-files-trademark-infringement-lawsuit-over-counterfeit-parts/
Moderator
OEM Motorcraft.
Why are you replacing the coil packs? Do you have a misfire code for all of them? Or, replacing aftermarket ones?
The OEM plugs for the EcoBoosts from Ford are NOT good. They have actually gotten worse with the current generation.
NGK 95605 plugs are definitely what most that know the Ecoboosts are recommending. Do a search on here. There are many threads about plugs.
OEM in this case is NOT the way to go.
jeff kushner
North of Annapolis
Thanks Loki, your timing is perfect. With 159K on my truck and the most recent plug change used 2nd tier plugs due to backorders, I needed new plugs....and here you are!
Thanks again Brother, hope all is well!
jeff
JasonH
Houston, TX
If you're feeling cheap, check your plug gaps. They open up over time and regapping might resolve your issue.. My boots disintegrated, so be prepared to replace those as well.
Moderator
This 100%. If you do go with OEM, check them out of the box, because the gaps will be all over the place. Actually you should check any plug before you install it. Gap is VERY important on modern motors.
Moderator
jeff
Anytime Jeff! Glad to help.
GlennSullivan
NY & FL
Here is the Coil Pack through Tasca Parts - big Ford Dealer so you don't need to be concerned about counterfeit parts. They also sell other OEM brands. I just bought some coil packs for my C6-Z06 Corvette, local dealer wanted $149, bought from them for $85.
Z
zach1027
texas
What’s the recommended gap for stock tune
Wangle
Des Moines, IA
Hello. 24k on my 2018 Limited. Had a couple instances of “stumble“ and a little bit of a rough idle. Completely stock except for a catch can. I’m going to do a plug replacement with the Ruthenium as recommended. I was wondering why the one step colder plug NGK 95605 is recommended for a stock set up instead of the normal heat range NGK 90495. Some short trips, but 80% longer trips and 35% towing, some light and some 7000 pound towing. Very light use overall, but she was manufactured the third week of October 2018. Just days away from being a 19. Will the colder plugs keep my cam phasers, turbo wastegate, and shocks from going out? Seriously, I’ve just lost two front shocks, and replaced the battery with an interstate for some weird electrical glitches that are now solved, so she has been a good one. I feel pretty lucky so far…
Timo2824
Wichita
I've had several 3.5's and the occasional stumble and rough idle seems to be normal. Your plugs should be good for 50-70k miles. I know drilling a weep hole in the intercooler really helps with the rough idle.
Moderator
Yes, You will most like experience a smoother idle. I have done one colder in all my EcoBoosts, and even stock they idle smoother.
Moderator
HAHAHA! Sure, you can run the stock plugs for 50-70K, but when you pulled them, did you look at them, and check the gap? I will bet you $100 they were all over the place. Even if you don't want to replace them, pull them and regap them. But if you are pulling them, why not replace them with better, that are gapped properly.
Wangle
Des Moines, IA
If I am going to pull the plugs, which I am, I will have new ones in hand and replace them. Also, I thought that the weep hole was rarely if ever needed on the GEN II ecoboost. It will probably be a month or two before I get to this, but I will post results.
Moderator
2015-2017 Expeditions have the 1st Gen 3.5TT EcoBoost with the 6Speed 6R80 Trans. It only has Direct Injection. The 2018+(4th Gens) received the Gen2 Motor and the 10 Speed. Expedition is ALWAYS behind the F150. Check to see if you have a weep hole before you drill one, but not a bad plan either.
Wangle
Des Moines, IA
Yeah, when I bought it I was looking for a used 2015-ish, but the GEN II upgrades won me over. Who knew about the cam phasers, shocks, and waste gates… LOL. At least I don’t have to worry so much about carbon buildup.
