2004 Ford Expedition - Best Recommendations to improve night time driving
jthrall76
Gardnerville, NV
Hello, I have a 2004 with 174k on it. I want to love it for at least another couple years.
When I drive at night and especially in the snow, the factory headlamps and fog lights are not great. I have already ordered yellow LED foglamps (9145), that I will put in the truck. Am interested if other folks have upgraded their headlamps ( 9005,9006) To LED and did they need ballast, which bulbs, how long did it take, etc, Mostly interested in snow visibility. Thanks!
Hamfisted
Ft Lauderdale
How are the lens on your headlamps ? Still clear, not glazed over, right ?
I've tried HIDs, LEDs, and found the Beamtech Fanless LEDs to offer the most compact package and best beam pattern. Installation is as simple as replacing the bulbs. You will need to pull the headlight housing out just like you would if you were replacing the bulb any other time. Order a pair of 9006 and 9005 on Amazon.
Beamtech Fanless LEDs on Amazon
whtbronco
Winchester, VA
Never once have I found my 2004 Expedition to lack light in front of it driving at night. However, due to the HID and LED headlights now days I wear sunglasses to drive at night now.
2020FordRaptor
Nevada
I've heard Fahren is really good.
Aspen03
Indianapolis
I'd have to agree on the factory lights in bith our 03 being pretty bright assuming housings are in good shape and aimed properly I have no issues seeing 1/4 mile up the county road that heads to our house, snow visibility has also never been an issue, even with the insane amount of deer that like to dart out. There are no street lights and they get the job done. I'm running silverstar halogen bulbs in factory housings.
From the couple I've seen running around here with expeditions and explorers of this era the LED bulbs are horrible for other drivers as the glare is intense with the reflector design on our years as it really causes the light to scatter eue to how the diode is positioned and the direction light is emitted. Some brands are better than others in this regard but it's an issue for most.
I will say the fog lights could do more but I deal with fog constantly due to driving through and area that dips very low where there is a large reservoir nearby and the road is always foggy to the point no amount of extra lights will help and I just slow down like everyone else.
riphip
Memphis, TN.
I have the Beamtech also and love them!! Have mine aimed down a hair but they are great. The Beamtechs were fairly easy to install & are going on 3 years. I'm in Memphis & most people drive with high beams on for some reason. My lowbeams are Very sufficient over the originals. Will replace headlight fixtures next time I replace bulbs. Newer/better replacements coming out all the time.
JamaicaJoe
Oviedo FL
I have a 2001 and the plastic housings are yellowed need polishing. Not too badly, but enough to reduce the beam. I am planning a repaint and after that I may buy new housings.
There is a Ford aftermarket company LMR who sells various lighting upgrades. I am going to buy the relay harness they sell for my generation that plugs into the existing headlamp sockets and provides DC directly from the battery instead of via the switch and fuse block. It is basically a plug in affair with a fly lead and fuse for the battery and ground. It will raise the voltage a volt or so and that can make all the difference in light output and color.
I am staying with Halogen because I have always preferred them and the aftermarket LED deals have focus issues and create electrical noise.
I am also considering some Hella rally style Halogen driving lamps on the grill to supplement.
NASCAR Mike
Syracuse NY
LED lightbulbs. I have the Fahren in my 08 and 17 Expy. They have fans to keep them cool. Driving at night is much improved and people don't flash their high beams at me so I will say I am not blinding anyone.
Jb14
I thought the stock bulbs to be somewhat lacking so I did a minor upgrade and switched out the main headlight bulbs to the Sylvania super white or a bright bulb or something like that and I was really surprised at how much better they were over stock so much so I also changed out the driving lights to same type. Probably 30% better (brighter, whiter) than stock
So for me when considering the cost and all that I read about the hit or miss on the LED and complete headlight upgrades cost I am completely satisfied.
Al Steel
I agree with others regarding plastic lens glazing. If your lenses are even slightly yellowed or glazed over it can greatly affect your beam pattern and brightness. Polish or replace glazed lenses and leave them stock.
Even driving on pitch black rural roads with deer, downed trees, and other possible hazards I have never found the stock lights too dim, especially with the high beams on.
I've tried the "bright white" bulbs but found the reflected whiter light too glaring and annoying for extended night driving. Clean or polish your lenses and use stock / slightly upgraded bulbs (Silverstars) but stay with the yellow hues. And for GOD'S sake don't go with those terrible "cool blue" lights.
Greye
May I suggest Hikari led headlights. I have used them in five different vehicles, two Fords, two Lincolns an a Hyundai (not mine thank goodness) and I have yet to have one fail in 3 years and counting. They have multiple options as to the type output and pattern. I've run three types except for the newest one out. They are a white 6K color as well which makes my night driving with my old eyes a pleasure.
getdealtwith
US
How easy or difficult is the lens replacement?
I have a 04 Navigator Ultimate with HID lamps and the lenses have pretty deep UV cracks that I haven't been able to sand through. I'd like to avoid buying new lamps but haven't been able to source new lenses. perhaps someone knows?
