Show your Lifted 3rd Gens
sleghamma
Seaford, NY
New to the forum.. I don’t know if I’m posting this the right way
Had her 2 Years. This is my 3rd Expedition that I’ve owned. Always wanted to lift one. Finally did it! I hate the rear wheel Tuck…..
New tires and Rims on the way!
Speedboosted
PNW
Seems pretty tall, what parts did you use to lift it?
sleghamma
Seaford, NY
Supreme suspensions 3/2 lift. It was to much in the front. Ended up jacking it almost 4+ inches in the front with KYB quick struts. I even drove on them a few weeks. My front CVs started throwing grease from the extreme pitch on them. I had limited turning radius. Just to much lift. Front suspension had zZERO down/return travel available. It rode like a brick on steroids. I removed the supposed 3+ lift pucks today and threw in a 2”. It made the world of difference to drive. Also leveled her out and gave it a better looking stance. IMO. Also removed the s**t Sensen struts and matched the back with KYB as well. Now she rides the way I want her to.
Speedboosted
PNW
New wheels/tires look good on there, nice call on going lower up front. Crazy how much bigger it is compared to the 4Runner behind.
Speedboosted
PNW
Finally get to contribute pictures to this thread after staring at it for over a year. Just a baby 1.25" lift all around since my stock sized tires are still in excellent shape and I like how the perform on every surface, so no desire to swap just yet. And I wanted to keep the rake.
Fronts: Eibach E60-35-037-06-10 on the 3rd highest setting
Rears: Bilstein 24-285063 on the 3rd highest setting
How's the ride quality? I haven't driven it more than a couple miles, but so far it's everything I hoped for. Front is buttery smooth and the rear is *slightly* firmer, which will be great when we're loaded up for camping trips or hauling my car to racetracks. I pretty much only use this for adventures (or Costco runs) so it has the back full of stuff 90% of the time. While the valving is slightly different between the two shocks, they are the same internal design so everything still works together seamlessly. 100% recommend this combo for most applications.
My 2017 4wd EL with standard shocks did not have any problems removing the spring perches nor compressing the springs with a basic rental one from O'Reillys. The rear shock bolt broke my 1/2" breaker bar, but aside from that everything was smooth sailing.
Future plans include replacing the tires (probably next spring/summer) with 275/70-18 Falken's new AT4W and Method 318 wheels. Will likely up the fronts and rears to the highest c clip setting at that time, which will give another 1/2" lift or so, and replace the front UCA's to avoid contact at full droop. Right now they still clear, but it's very tight.
ediddily
Nevada
I see the Ready Lift spacers being $400. I found a spacer set for $150 from Supreme Suspensions. Anyone familiar with Supreme Suspensions? Any good? Seems same solid piece build.
ThwopKing
Bunker hill, WV
Supreme is what's on my truck... was like that when I got it. Lots of these spacers are the same just look for quality strong hardware and thick material.
laketrash
Central TX
Updated wheels and tires, 20x9 +12 offset, 295/55/20 ridge grapplers, zero rub and no cutting but my sides steps were broken when I bought the truck (one was sheared off and gone) so I removed the other.0E86AFB5-1BB7-48C8-AF31-DC7DF26E9434.png1212D5D6-E8C7-4E9B-A227-F4E83A25ED1B.png
sharprd65
