Brakes locking up
Gregory 60
Auburn CA
I have a 2001 Expedition just recently I have a problem with breaks locking up ( thankfully it did not happen on highway) I have been trying to find any info on this and what can cause the issue the abs and adv track have been on for a while and have been looking for parts.
The adv. track came on at the same time I found out it could be caused by a bad speed sensor, could this make the abs to stop all wheels the
Hamfisted
Ft Lauderdale
Do you have a scan tool ( or ForScan ...) that will read ABS codes ? What codes are you getting ?
Yupster Dog
Moderator
Please check your vehicle's year again, as a 2001 does not have advanced track or wheel speed sensors.
If you do have a 2001 it could be a stuck caliper pin or a stuck caliper piston. Remove wheels and check brake pads for uneven wear. (rear brakes remove rotors to check parking brakes as well)
Welcome to the forum
G
Gregory 60
Auburn CA
built 9/22 I am in the process of replacing wheel sensors, but ran into more problems seams that the left front axel and actuator have been busted and found the lower ball joint boot gone took steering knuckle off but now have to find a way to remove the remaining part of axel from transfer case. socket wrench just causes it to rotate suggestions on how to remove it
JamaicaJoe
Oviedo FL
I also have a 2001 and I had past problems with right rear caliper dragging and overheating the disc. It got so bad that the oil seal melted and diff oil smoked. The problem was resolved by replacing rear calipers and all of the rubber hoses in the hydraulic system, front and rear.
G
Gregory 60
Auburn CA
I have a 2003 Expedition I have found several things wrong with front end the actuators are shot the boots are torn, I decided to replace all the struts as well and add a 3" front and 2" rear lift got new axels for front got strut and axel in on left side having a problem getting the bar that is on frame to the back side to line up also replaced lower ball joints will I need to adjust the bar to get it to line up
G
Gregory 60
Auburn CA
The bar I am talking about is the stabilizer
G
Gregory 60
Auburn CA
Machete
My Rig. 2000 EB 4x4 5.4L
Illinois
Calipers sticking?
