Doug Shumway
So…tranny still pops out of gear on the freeway while cruising then giving it gas to pass! The CDF swap fixed it for a while but the problem is back! Anyone know what the next step is?
Thanks
Thanks
My 2019 is still acting up after CDF replacement, it was fine for awhile and is now shifting poorly. It goes in Tuesday, hopefully for a full replacement. Been waiting 7 weeks for this appt since we had the "reflash" done as was required....So…tranny still pops out of gear on the freeway while cruising then giving it gas to pass! The CDF swap fixed it for a while but the problem is back! Anyone know what the next step is?
Thanks
Was the new oneThe new cdf drum was probably also bad from the manufacturer and or not the new updated one being lroduced now?
Yeah…just wondering if a NEW tranny will be any better? Just wondering if anyone else has had to go this route? It sucks because this thing only has 34,000 miles on it!The dealer most certainly would have reset the tranny learning sequence after doing the cdf drum work, doubt that will do anything. If it’s repeatable, record a video of it, and/or have them go on a ride along with you. I would think the next step would be a new tranny, but they may make you try two or three other things, like a full valve body, etc.
As far as I know, the neutral out condition is caused by valve body issues and park hydraulic circuit leak and not the CDF drum failure.I’ll keep ya’ posted
I still got a new CDF drum in the process with mine.As far as I know, the neutral out condition is caused by valve body issues and park hydraulic circuit leak and not the CDF drum failure.
Trans is “toast” according to the dealer, they’re getting approval from ford to install a crate factory remanned transmission (still under factory power train) Should know by end of week.Keep us up to date please.
New crate transmission approved and on order from Ford. 3-4 weeks until install.Trans is “toast” according to the dealer, they’re getting approval from ford to install a crate factory remanned transmission (still under factory power train) Should know by end of week.
