2021 FX4 Tranny problems STILL after CDF fix
Doug Shumway
Riverside ca
So…tranny still pops out of gear on the freeway while cruising then giving it gas to pass! The CDF swap fixed it for a while but the problem is back! Anyone know what the next step is?
Thanks
S20Workstation4
Hyde Park, NY
First thing I would try is to reset the Transmission adaptive learning.
If that doesn't work, I would take it back to the dealer, show them the TSB and your symptoms, and see what they say...
Joe
5280tunage
colorado
The dealer most certainly would have reset the tranny learning sequence after doing the cdf drum work, doubt that will do anything. If its repeatable, record a video of it, and/or have them go on a ride along with you. I would think the next step would be a new tranny, but they may make you try two or three other things, like a full valve body, etc.
SyndicateZ
Mass
The new cdf drum was probably also bad from the manufacturer and or not the new updated one being lroduced now?
GixxerJasen
DFW TX
It's highly likely when it did that, that a fault code was stored. I'd have the dealer check to see if anything is in there. I know when I took mine in for the rebuild, mine was full of fault codes. I'm having similar issues post rebuild and need to schedule time to take it by. It's also intermittent, I can't actually make it do it, but it surprises me from time to time. Curious to see where yours goes.
Jettix2
Frankfort, MI
Thanks
My 2019 is still acting up after CDF replacement, it was fine for awhile and is now shifting poorly. It goes in Tuesday, hopefully for a full replacement. Been waiting 7 weeks for this appt since we had the "reflash" done as was required....
D
Doug Shumway
Riverside ca
The dealer most certainly would have reset the tranny learning sequence after doing the cdf drum work, doubt that will do anything. If it’s repeatable, record a video of it, and/or have them go on a ride along with you. I would think the next step would be a new tranny, but they may make you try two or three other things, like a full valve body, etc.
Yeah…just wondering if a NEW tranny will be any better? Just wondering if anyone else has had to go this route? It sucks because this thing only has 34,000 miles on it!
GlennSullivan
NY & FL
This is absolutely criminal that transmissions are failing in low mile conditions. Does anyone know if these problems have been resolved on 2024 Expy's or is it still ongoing?
GixxerJasen
DFW TX
Well, considering that the older vehicles are being rebuilt with the new parts that should be the same ones in the 2024 models, and still having issues post rebuild...
Guess we'll have to wait till more of the 2024 models have 30-50K on them to see.
GlennSullivan
NY & FL
This is interesting. I tried comparing transmission parts from 2020 and 2024 Expedition Limited on Tasca Parts, but no 2024 parts were listed, so I compared 2023 and 2020 and the Valve Bodies are different part numbers. Additionally some of the solenoids show as discontinued. Maybe, just maybe they are improving what (at least to me) seems to be a disastrous product quality / customer satisfaction situation.
In the meantime, I'm going to sit on the sidelines and keep my 3 existing full size SUVs.
Jettix2
Frankfort, MI
Trans is “toast” according to the dealer, they’re getting approval from ford to install a crate factory remanned transmission (still under factory power train) Should know by end of week.
New crate transmission approved and on order from Ford. 3-4 weeks until install.
