Let's See Those Lifted / Big Tire Gen 4s!!
Rednecked
Arizona
I have only been lifted for about 3 weeks now. My first trip off-road trail riding is next week so I will report out on how that goes.
But as far as everyday drivability here’s my take:
I did the ReadyLift and the rear sway bar and end links all at once. Still had the factory 22’s and factory size tires. I didn’t notice much difference in the front, but the back was much stiffer. For example, going over a speed bump: before my Expy was very squishy when the back went over a speed bump. It felt like the rear shocks went full travel both directions and would continue to bounce up and down MANY times after going over it. After the lift and sway bar, the rear end felt much more truck-like: The compression was less, and the rebound was immediate and solidly planted the rear tires back at normal spring height. It was a trade off. Much improved handling and responsiveness (far less bobble head and porpoising) but harsher ride in the back even in eco mode.
Then I replaced the front sway bar and end links when it finally came in and any doubts I had were gone.
The sway bars are the answer.
If all you are doing is the ReadyLift then I don’t think you will notice much change in your CCD performance at all. But make sure you IMMEDIATELY get it aligned AND get the CCD shocks reprogrammed for the new ride height.
The sway bars and end links will make the small bumps more noticeable but anything you give up in floaty Cadillac ride is more than made up for with the improved driving dynamics and eliminating the bobble head/porpoising.
To finish up my transformation I replaced my 22’s with 18’s, and went from the factory 32.1 inch tire to a 34.3 inch E-rated Nitto.
As stunned as I was after the installing the front sway bar, the transformation after the new wheel/tires was equally amazing.
I went from having 5 inches of sidewall to over 8 inches of sidewall.
This completely eliminates small bump harshness and it just crushes road imperfections and potholes.
I leave CCD in normal mode and this thing is just a dream to drive now. It has serious truck toughness now but still a smooth supple ride thanks to the HUGE Nittos. I have zero rub front or back, still plenty of travel, and no topping out. Haven’t tested it off-road yet, but I will take some pictures in Moab and Sand Dune National park in the next 2 weeks and let you know.
It’s no Raptor, but I’m really happy with it for the first time ever really. Probably the only way to do better with this truck is a full custom ICON suspension costing 4-5 times as much, and you still would have locked in warning lights from the CCD-delete and probably be cutting body panels also.
In summary: the factory sway bars are junk and the 22’s make it ride like $hit. Get rid of both of those. Want to add 3-4 inches of ground clearance? The ReadyLift and bigger tires do a nice job with minimal impact to ride.
What do you mean get your CCD suspension reprogrammed?
Rednecked
Arizona
Finally got around to finish my Expy!
ReadyLift 3in front. I left the rear stock. I prefer a slight squat. 1in lower in rear to be exact.
Falken tires 285/70r17. No cutting, No trimming. I had to move the auto step about 1/2 back.
Raceline Rims 17x8.5 w/ 0 Offset (4.75" Backspace)
***UPDATE***
I added a 1in rough country spacer in the rear. See last pic.
Mack444
CA
It is Timberline spec. I’m very happy with the wheels!
Flying N
Not lifted but brand new larger A/T tires on stock wheels. 285/50r22. Took it for car wash, and of course they put a shine on the tires. A/T tires... Oh well, they still look good IMO.
doubleeagle45
Georgia
View attachment 77562View attachment 77563View attachment 77564295/70 R18 Toyo Rt Trail on stock Timberline rims and suspension. Didn't have to trim or move anything. Haven't noted any rubbing with normal driving. Thank you to earlier posters with their setups.
Looks really nice! How much noisier are these RT compared to the stock all-terrains? Keeping an eye out for the eventual replacements when my Timberline needs new shoes....
leirej
SoCal
I didnt spend too much time with the stock tires but have 12k miles on the toyos now and tire noise is not an issue at all.
doubleeagle45
Georgia
I’ve had my ‘18 max Plati since ‘19
Lifted 3”, RCI skid plates, Kingdom Overlanding roof rack(awesome) Vision 18” rims(discount tires), Nitto grappler tires. I just ordered a Raptor grille and DEchroming as we speak. I use it hunting and in the Utah snow. Does great.
Looks like the comfiest "hunting rig" I can think of!!
(most of the ones I've been in feel like a broken old dump truck and have me worried I might have to walk back to civilization.. ha!)
Thelastboyscout13
I know not an Expedition. But here is our Gator with KMC IMS wheels and Toyo rubber.
Stock height.
KMC IMS 18X9 18MM
Toyo MT 285 65 18
normunrau
fort mcmurray, alberta
Swapped out the Stealth 22's for a set of F150 Tremor takeoffs. Good, bad, right or wrong, I used a 1/2" spacers (which isn't noticeable) on the rear axle rather than cutting the spindle threads to get the center caps to fit. Ride is significantly improved and it no longer has that bouncy feel on the highway.
Looks Great. What size are those tires? Any rubbing?
C5Brasie
US
5’1 wife n small kids don’t like jumping or being tossed into my truck so she didn’t want her vehicle to be tall.
No lift however, the 285/70r18 sidewall lifted it slightly.
Wheels and tires were purchased well before the vehicle based on info from this thread so she says thanks.
GixxerJasen
DFW TX
Those wheels look good on the truck. I can sympathize though, my FIL lives with us and rides with us and is handicapped and already has a hard time with the height. I'd lift it otherwise.
C5Brasie
US
Yeah with 3girls 5y/o -4months it’s easier to not lift them above her shoulders to put them in my truck so 90% of family time will be in this as her 2012 Explorer becomes my run around town vehicle to keep miles off the super dumpy.
slimcubby
Idaho
We just purchased a 2024 Expedition Max Stealth package and went to do the same setup this dealership has done. I called and they said it was just a spacer to level. Anyone else running this tire size setup and what would you recommend to achieve this setup? I’m new to the forum and thank you for your help and advice.
