2024 expedition vibration
jcexpy
new mexico
Hello everyone, new here just bought an new 2024 expedition limited max in December. Have the same vibration and shaking as others have stated above 65mpg and worse above 75mph, took into ford and they told me 3 of the new tires were out of round. So if you road force balance it won’t be caught. They need to inspect for out of round on the tire. When I took my car to discount tires they did not catch this, they just balanced and sent me on my way not correcting the issue or even finding it. Hope this info helps someone.
fastflyer20
Buffalo
Early in my career I designed tires. It sounds like tire uniformity, however, suspension and chassis can exasperate it. The shorter the sidewall, the more it gets amplified, or less forgiving. I prefer a taller sidewall, funny they shorten the sidewall on the higher trim levels due to the look, not the ride quality! The tires are the first link in the suspension. Whatever the tire can not absorb, the suspension has to absorb or transmit to the chassis. The lower the sidewall, the more forces are transferred to the suspension. This makes sense for high-performance applications, but I question the logic for everyday vehicles. We most likely have the sales/marketing groups to thank! All tires should be quality-checked by the tire manufacturer for uniformity, but there are acceptable levels where some are better than others. Where I worked, each tire was measured and marked 1-4 "bars" which were painted on them for future reference. 1-3 bars were sellable. 4 bars were scrap. I analyzed all the levels and would not want any 3 bar tires on my vehicles. Sometimes you can visually see the runout, other times it takes measuring equipment to determine the forces caused by the internal tire structure. We had one vehicle manufacturer with poor chassis design, crazy things had to be done with the tire design to make up for the OEM's unwillingness to do the more expensive fix to the suspension/chassis. So there is a relationship between the tires and the suspension/chassis, however, the tires would be the cheapest and easiest to try. You could request to test tires with a higher sidewall from a lower trim level. If it fixes it, clearly it was a tire issue. Or request new tires screened by the tire manufacturer. I would also ask for the local Ford rep to review the situation. This is most likely beyond the dealers' capability and/or authority. This is a quick summary, I hope this helps give some information towards getting future issues like this resolved.
Schulminator
Oviedo, FL
Will be ordering new tires in the next week or so. Going with Michelins, should we go with Defender LTX M/S2 or Primacy M/S? We are in FL with 99% street driving.
Skud
OH
Does anyone have any contacts or paths when the dealer and Ford customer service isn't helping?
I've had a vibration since the vehicle was new and I have 9 documented balances. On my last visit to the dealer they suggested that we try a road force balance. I was dumbfounded because I thought they had been doing RF balances all along. They said that I needed to specifically tell them to do a RF balance :rolleyes:. Lo and behold, two tires failed. They put those on the back and the vibrations are much better. So, this is what's been happening all long and why the vibration comes and goes. They would balance and rotate the tires and depending on the location, I would have a vibration.
Here's the kicker - they're now telling me I'm too far over on mileage. I was at 35k when we found this out. I swap with winters, so these tires have maybe 20k on them, but of course they won't take that.
I called Ford and they told me that the warranty is 12k. Even before I had a chance to discuss further the CSR told me that the policy is firm, no one else can help me, and there is nowhere to escalate. I was a bit surprised as I hadn't asked for any escalation. The dealer is telling me to go contact the tire manufacturer and their Ford rep denied any claim.
My winter set is on right now and there are no vibrations.
Riley
Follow-up to my issues....
Dealer kept telling me that they were following-up with the local Ford rep and then strung me along for 6 months. Always said they were out sick, "I will check and let you know" (but never would), etc. Finally, they said the rep told them that the vehicle has 42k (which was the current mileage) on it now so it's too far out. Didn't matter that I reported the issues all the way back from 0 miles and had it all documented. Also didn't matter that they said 6 months ago the rep was going to look at it. Called Ford customer service back again and they said the same thing. If the dealer didn't ever submit a claim then it's going to be whatever the current mileage is. They passed it off to the dealer and said each dealer is independently owned and Ford has no control over them (yeah, right..). They did offer to call the dealer on my behalf and that's when things started moving - so maybe they said something to them?
I ended-up following up with the dealer each week and being a general pain until they said they would do a 50/50 split on new tires. Gave me the option of the same tires - General Grabber and some other low-cost options. I told them I wanted Michelin Defenders, and they agreed. They told me they didn't feel they should have had to pay anything. I agreed with them and said if they had diagnosed the issue correctly, earlier, then Ford would have paid under warranty.
Dropped off the wheels and they changed them out last week - still have my winter set on so it will be a couple weeks until I get to try them.
Torch1972
Got rid of the factory Grabbers and all is good. Ford replaced them on their dime, wanted Michelins, gave me Hankooks which are not good tires either
Skud
OH
Finally got a chance to swap my winters for the new Michelin Defenders - I'd say it's solved. Smooth up to 80mph. Ride is great. New problem - I can't tell how fast I'm going by how much it shakes anymore. I need to look at the cluster..
Schulminator
Oviedo, FL
They checked wheels to ensure they were all true, which they were. Roadforce balanced, might ask them to double check the balance again.
MrZeke
I purchased a 2024 Stealth about a month ago, equipped with Pirelli Scorpion tires. I've previously used this brand on other SUVs without any issues. I'm experiencing the same vibration issue above 75 mph—it comes and goes throughout the vehicle.
I had the tires road-force balanced, and while it improved slightly, the vibration persists. I truly want to enjoy this Stealth, but encountering this type of issue on a vehicle priced over $75,000 is frustrating, especially as I commute around 70 miles daily on the Turnpike.
evzerb
NY
Hello, new to this forum. Surprised it’s taken me this long to look into this here! 2024 Expedition MAX Limited 22” with general grabber tires. Same vibration over 70mph. Complained from day 1 as I do a lot of highway driving. Has been to the dealer no less than four times. Road for balanced all of them multiple times, exchanged rims and tires with another car on the lot, replaced all four tires with new grabbers, problem persists. Even had the master tech perform some special road force with measurements and everything. I keep insisting it has to be something mechanical outside of the tires. Like driveshaft. Has anyone had success with eliminating the shudder?
Fastcar
Army
FL
Old school. Get a worm clamp big enough to fit around your driveshaft and apply it. It's a pia but moving it around and noticeing the change in vibration may head you in the right direction.
ib_jigged
NW MN
A new set of Pirelli Scorpion AS3 plus tires took care of the issue on ours! Dealer found one of the General Crappers was bad.
Left Coast Geek
Mid Left Coast
my 2019 Stealth came with those 22's, and while they rode OK with the CCD, I drive on a lot of really crappy remote roads and wanted somethign that wouldn't fail on a pinch flat, so swapped the 22's for 18's almost as soon as I got the SUV. Still using the crappy stock 18" tires that came on an '23 F150 FX4 ("Goodyear Wrangler Territory AT"), can't wait til they are worn enough to replace.
the 22's
the 18's
the 18's a year and a half and 15000 miles later, with a bit of Tahoe snow, from Saturday morning...
sjwhiteley
Kentucky
So, maybe, or maybe not related: I had a vibration that ramped up above 65 to 70mph. I had 5mm spacers on stock wheels with tires with around 20k miles on them.
I took the spacers on the front off, cleaned off the faces on the brakes and wheel (seemed ok) and put the wheels back on carefully tightening the bolts making sure the wheel was evenly put on. The vibration went away.
audiovettes317
florida
Hey new here! What was the final best fix outside of new tires? We have a 2024 max stealth and it has been shaking above 70mph since the day we bought it (brand new). We have serviced it 4 times for a fix and at 2 different dealers. Each time they have agreed there is excessive vibration, and ended up simply swapping out tires / rebalancing / moving weights etc. eventually the Tech at our local dealer said this vibration is a known issue, Ford knows about it, but doesn’t have a fix for the dealers (may be too costly for Ford) so we are hosed. Applied for Lemon Law, Ford denied after they magically upped their “acceptable” vibration ratings on April 23rd, 2025 - so we tried Buy Back which was also denied since it’s now within their acceptable vibration. It’s terrible. $80k down the tube, trade in value is garbage since $25k depreciation is already in. Looking for any solution- we really love the car minus the awful shaking + terrible experience with Ford. Also wild that we have bought 3 new cars from them and have been loyal customers and this is the repayment! LOL
Left Coast Geek
Mid Left Coast
I'd bring it to a good indepedent tire dealer, and ask them to balance the wheels and check them for out of round. I have no vibration in my 80K mile 2019 even at speeds approaching 100MPH.
audiovettes317
florida
Thanks. The Ford tech said that he believes it’s an issue on the 2021-2024 because they increased tow on it - I really have no clue but my brother also has a 2019 max with 0 shaking issues
