2024 expedition vibration
Mr Big
Tampa Bay, Florida USA
Mentioned several times in different threads, on this forum.
If the dealer installed some fix-a-flat goop into the tires, it sometimes causes vibration similar to out of balance at speeds above 65mph. I had the issue with mine, but never knew what was causing it. When I got new tires installed, under a pro-rated warranty claim, they found clumps of the stuff gathered together inside the tires. They blamed that for the out of balance vibration, as it will shift with heat.
I run Michelin Defender 285/45 R22s and they are as smooth as glass at any speed. That combined with my CCD suspension and it's like riding on air.
It may be a longshot for those who are experiencing this problem, but worth asking the dealer.
Fastcar
Army
FL
Yup, that will do it. A couple of friends used that and it raised hell with the balance.
Flathead40
Nebraska
We had a vibration problem in our 23 Max Limited. Started to notice it around 25k miles and thought it was a tire balance issue. Had the stock 22s rebalanced and did not help anything. At around 30k we put on 20” wheels with 285/55 R20 Michelin Defenders and had a hell of a time with balancing them or so we thought. At around 50k started to hear what sounded like a wheel bearing noise coming from the front and finally got into the dealer around 55k. Dealer replaced both front hubs, said they were both bad, which i thought was odd. Get it back and vibration and noise is actually worse. I ended up putting it in gear on jack stands to troubleshoot and pinpointed to the front diff. Took it back to the dealer and after 2 weeks got it back and finally fixed. Turns out pinion bearing was bad as well as right hand carrier bearing, which actually spun and the race wallowed out the inside of the case.
I wonder with Ford ditching it he IWEs and spinning the front diff all the time if this is not going to be a more prevalent issue. Also wonder if this is not the source for some other’s vibration problems.
Fastcar
Army
FL
I was under the impression, perhaps wrongly, that the vibration was coming and being felt all through the truck. not just the front and being transmitted through the steering wheel.
Flathead40
Nebraska
I think that is true that it is felt throughout... but if there is a front differential problem like we encountered that vibration will travel through the drivetrain since everything is spinning even in 2wd on the 22+. Again, just a theory from my experience on our 23.
Also, I feel like there is just harmonic issues with these. Road vibrations and bumps seem to resonate throughout chassis. Don't know if it is more prevalent on the Max vs the standard WB or not, but the 22" wheels just compound the issue. Ours does not have the CCD, which may change things as well.
Fastcar
Army
FL
I've found that anything screwed up on the front end is usually felt in the steering wheel, vibrations from the rear are felt under your ass. Regarding the CCD, I've had that on my 2021 KR and on my current Limited Stealth. Both have had General tires on them without much of an issue. Also both are standard WB. Be interesting to see if the extended WB is more prone to the vibration than the standard WB.
You mentioned harmonic issues. Probably from the exhaust system. That will telegraph all over the place.
Schulminator
Oviedo, FL
My wife took her 22 into a local tire shop recently, after having Michelin defenders installed about a two months ago at our local Ford dealership (they had the best pricing). She had the tire shop pull the wheels and put them on the road force balancer without doing anything, all tires were off by about 1/2 oz with one of the fronts being off 1.25oz. Needless to say after they rebalanced all the truck now rides perfectly at highway speeds.
RazrM5
Miami, FL U S A
July 2025 update.
Brought the vehicle in for pre-long distance travel service.
Oil change plus tire rotation.
In some miraculous fashion, the tire rotation completely disintegrated the vibration. I can drive the vehicle now close to 90 miles an hour and the vibration is nearly imperceptible.
I’m attributing this to the quality of the Michelin defenders/the most current rotation/who the hell knows…
It does appear that it’s going to take 20,000 miles and some luck with really good tires.
I’m wondering if there’s been any feedback on the 2025 models — particularly the Stealth editions and any vibration noticed.
rbrown6061
My 2024 Expedition XLT had the same problem.. Horrible wheel vibrations when I picked it up.. I COULD have gone to the dealership and had them rotate/balance the tires (assuming that was the problem).. but.. that's a one time rotate/balance for free under warranty.... future rotate/balances would be on my dime and expensive.. so... .. I went to Discount Tire and paid for the "lifetime" (of that set of tires) rotate and balance.. they had a really hard time GETTING the tires balanced (road force and all).. for several of the tires, they had to remove the tire and "rotate" the tire position on wheel to make it better.. I think it MAY also be in part due to the (my humble opinion) crappy tires that came on it from the factory (Toyo HT/d Open Country). I'll bet once these tires are worn out, and I replace them with my favorite tire brand (Michelin) my balance issues will be a thing of the past. (Discount Tire also checked the alloy wheels to be sure they weren't out of round and they weren't). We'll see..
Fastcar
Army
FL
July 2025 update.
When I test drove ours there was a slight vibration felt in the steering wheel. Told them I wanted it gone. It was delivered and rides beautiful. Firm but no vibration of any kind at any speed. Guess I was lucky or my dealer had a tire guy who knew what he was doing.
Just a thought, keep track of where the tires were initially and where they are now.
young dude co
Hasn't it been decided already that the General Grabbers and whatever else used before Aug 2024 builds were the issue? That's presumably why Ford went with Pirelli Scorpion Verde after that. I have the Pirelli tires and never noticed it up to 100 MPH on the Limited Max (haven't drove it faster than that).
Fastcar
Army
FL
I have grabbers on mine only problem was one out of balance from the factory. I've had pirelli's on a Charger SRT and they truly sucked! Wet or dry, horrible. If somebody were to give me a set I wouldn't mount them, I'd get rid of them one way or another.
Ford and every other maker goes with whatever tire is the least expensive.
Saint Paul, MN
Took mine in on Friday for vibration and a clunking from drivers side front corner. Getting a new strut, only 1800 miles on the truck?!?! Hope that resolves vibration too.
Saint Paul, MN
New strut and an alignment later, still a noise… scheduled to go back in a couple of weeks when they have a loaner so they can take the dash apart as they think that’s where the noise is coming from.
Saint Paul, MN
And confirmed that one tire had excessive run out, so that is being replaced today. Fingers crossed that resolves it before a road trip to South Dakota and their 80 mph speed limits.
ib_jigged
NW MN
Does yours still have the General Grabbers on it? Ours had one that would not balance last year when we bought it. Put a new set of Pirelli Scorpion ASplus 3's on it and the vibration went away! I was worried that they would not be a good tire in the winter, but even with what winter we had up in NW Minnesota last year, they were great on the ice and snow. I have to say they are the smoothest and quietest tires I have ever ran, even better than any Michelin I have had.
Saint Paul, MN
It does. And only have 2700 miles on the truck.
Can’t make this up, new tire showed up, it also had excessive run out so still waiting on another new one?!?!
