UstonXpedition
Expedition started to run alittle hot. It was fine with the 170spd thermostat for a couple months. Found multiple leaks. 1 from the heater hose T and one front the hose connected to the reservoir. So I ended up going ahead and started to replace both heater hose, and the upper radiator hose. Also replacing waterpump, valve covers. SInce its cracked and leaking from driver side, and adding a true cool 40k cooler. But instead of deleting the heat exchanger. I will be running from the exchanger to the trans cooler. Now since I have no history of the vehicles. I was wondering if it would be safe to drain and replace the transmission filter?. Mileage is at 136k.
