Cam phasers and water pump replacement at dealer.
keny01998
Arkansas
Local Ford dealer wants $4800 to change the cam phasers and new water pump for my 2019 Ford Expedition XLT at 130k miles. Is it a good price? They want $800 to replace the water pump alone as preventive maintenance. My Exp rattled around first 10 seconds of cold start and the phasers were replaced under warranty at 41k miles in 2021.
Will Ford help with the cost or I have to shell it out of my pocket?
S20Workstation4
Hyde Park, NY
$4800 sounds about right. I think they do the timing chains w/ Phasers as well. All the seals, other required stuff....etc.
I think you're way past the warranty period for the Cam phasers....130k miles is a lot.
bb37
Member Relations Specialist
Indiana
I hope they replace timing chains when they replace the phasers. Seems silly to go that far into the engine and not replace them.
@keny01998 You might also consider having the valve covers replaced while they are in there. They are prone to leaking.
K
keny01998
Arkansas
Updates: I just set an appointment with an independent mechanic and he charges $2200 for 13 hours labor. The Ford OEM timing chain kit and other parts like water pump, heater hoses cost $1700 from Ford dealer. Hopefully it will be done next week.
Left Coast Geek
Mid Left Coast
yeah, i just had a quality independent do the phaser job, they used the full Ford kit, and it was close to $6000 out the door. labor costs are high here, $200/hour at decent shops.
