So, an update to the debacle everyone is facing with trailer brake controllers. Behind the in-dash coin holder in a grey plug that looks like it's plugged in, but it is only a dead socket to protect the connector. This magically matches the pigtail I found in the undertray in the rear next to the jack. (described above). I purchased a REDARC Tow Pro Liberty trailer brake controller with the universal pigtail harness, matched all the wires, soldered them and heat-shrinked. After a few choice words and scratches trying to fish the harness down to where the pedals and lower airbag, I was able to plug it all in. I hooked up my Trail Manor Camper, test drove and it worked beautifully. No FORScan needed. in the process, to make a nice mounting spot for the REDARC gain/e-braking knob, I butchered useless coin holder by cutting it down flush to just the frame, drilled a big hole in the back, and custom made a face plate to go on top of the remnants of the frame out of a textured piece of sheet metal. I used a plastic epoxy to glue it on, a little satin-black spray paint (didn't have flat black) and it looks great. It works great too! no re-doing a bunch of pins in connectors, no reprogramming anything... it just works! I will add pics later if interested
