Headers
Blueoval76
Sussex WI
What headers are you guys running? I have to do the manifolds on my truck and I would prefer headers. I like power but long tubes are out of the question since I need bolt in and I really cant afford stainless ones. I plan on ceramic coating them with a special coating I have used a few times in the past with excellent results including a 40 degree drop in temps. I am looking at the Summit brand ones currently.
Canadian Expy
Toronto ON
I using Gibson but most guys will tell you shorty headers are not worth the money. I like mine !
rewarder
Phoenix
Would headers bring down the engine temp? I live in Phoenix Az and the summer temps get 110 - 115+ I'm looking for anything to keep my temp down to a minimum - Hunter
B
Blueoval76
Sussex WI
I did see that shortys arent worth it if you want to make power which I knew about already. I am just fixing my leaks and broken studs not really looking to make max power since its got 260K on it already! Lol! I have already deleted the muffler and ran straight pipe.
It isnt really the headers that lowers the temp its the ceramic coating that I use that lowers the temps.
Newport News, VA
change your thermostat if you want to lower temps...JET Performance makes a thermostat that will lower temps...i have one but still need to put it in...WHOISMOOTOO has his installed...pm him if you want to know more about it...
rewarder
Phoenix
That Jet Performance doesn't sound too bad. It's only like $17.00!! I think I can handle that.
toms89
technical advisor
MD
I am using BBK 1 5/8" ceramic coated shorty headers. They are coated inside and out. They work great at keeping my underhood temps down. I swear they are lower now than it was stock. I would stick with 1 1/2" on stock 5.4 to not loose any low end torque.
Thermo
technical advisor
LIke has been mentioned, the heat under the hood is decreased due to the "insulation" put on the headers, not from the headers themselves. You can get the same sort of "cooling" for under the hood by using some header tape. Granted, the coating is a bit more eye appealing.
toms89
technical advisor
MD
I personally stay away from header wrap. Tried it on my stang and its a PITA to install plus it is known to accelerate rusting and deterioration of your headers. One of ceramic coatings greatest benefits comes from coating the inside of the headers. It "reflects" the heat away and keeps it from being absorbed by the headers.
panda24619
San Diego
so no header tape? i want my heat to go down as well. but also if you need new manifolds thats when you put in new shortys. since they need to be replaced anyways.
toms89
technical advisor
MD
Header wrap works but much prefer ceramic coating for reasons mentioned above.
mmrseed
Huntsville
shorty headers are worthless and unlike a 5.0 fox mustang they are NOT at all fun to put on. Also, overlooked often but if you wanna decrease temps (slightly) remove the sound deadening hood liner...traps lots of heat
Newport News, VA
one of mods coming soon...prob next year is venting the side fenders...that should release some heat...
2000eb
Hey hunter autozone carries low temp thermostats in their lil performance section. Im gonna do electric fans an oil cooler larger tranny cooler both with small fans on temp switches and edge programmer to up shift pressure which will lower trans temp due to less slipage ....sorry if cant spell just had surgery still in hospital full of tubes and hydroMORPHine.
SOLISIMO
Ft. Lauderdale
X10000000000000 about the rusting. And on top of that, I had them on my G37 to reduce the rasp. It worked but the problem is that when it rained or in the morning with the dew it smelled like something was buring since the wrap was getting hot.
rewarder
Phoenix
I'm probably nuts but I think I found some long tube headers. I did a quick google search and found these: http://www.pacesetterexhaust.com/headers_truck.php#notes
They say they fit 1999 Ford Expedition 5.4L XLT and other years. Is this true? Or are these guys selling bogus stuff? They also have them on Ebay for like $295.00 Someone set me straight.
Get out of the hospital - they have horrible food!! Stay Healthy and thanks for the info. I'll check into it.
toms89
technical advisor
MD
I would agree on a bone stock expy. They do not work to scavange exhaust like tuned (long tube) headers. But done as part of a system, say the rest of the exhaust is addressed also, they will reduce back pressure due to the larger size of the primaries. Just like any other mod short of maybe programmer or gears the whole system needs to be addressed. The factory has well matched all the components as a whole so no one component typically by itself does much.
I needed much higher flowing exhaust with my set up. So I went with 1 5/8" shorties since long tubes were unavailable. The ceramic coating was an extra that I went for (seen it used on mustangs) and was amazed at how well it actually works. You do not get the radiant heat you typically get with headers or cast manifold. This is why under hood temps are dramatically reduced.
toms89
technical advisor
MD
Look at Note 14
Then try and find them when you click on ford longtube headers.
