2004 XLT. Raidio stayikg powred
Bigfish708
Chicago
When I turn my 2004 expedition XLT off and open the doors, there is power still at dome lights, radio and windows.
Hamfisted
Ft Lauderdale
Does the front passenger door turn everything off when you open it ? If it operates correctly but your driver's door won't turn everything off, it's probably the driver's door jamb switch. It's located in the door latch (bottom). They're available from Rock Auto, be sure to order the correct side ( left and right are different orientation ).
B
Bigfish708
Chicago
Nort
I can open both doors and it still stays on , I even sprayed the lock mechanic with WD and opened and closed a few times. Do you happen to know what fuse or relay so I can test?
Hamfisted
Ft Lauderdale
The accessory delay relay is the middle fat one on the top of the fusebox. You can swap it with one of the others on the bottom row to test the function. If you don't have one, and you want to download it, the service manual is here: https://spaces.hightail.com/space/hoVVsN5P2A
B
Bigfish708
Chicago
Thanks. I tried swapping it and its still doing the same thing. I jumped the door switched on driver side and still nothing.
Hamfisted
Ft Lauderdale
Might be worth pulling the door panel and latch and visually inspecting the door jamb switch on both front doors. If you're not getting a "Door Ajar" message on the message center (if you have it...) when you open a front door, they're not working right.
