No ac no compressor freon full
Jbracer
Indiana
Have 2010 with no AC. Last year checked with manifold gauges and was good pressures. Drew system down and refilled and AC worked. Let vehicle sit for a while(couple months) and no AC again. Pressures still look good but no compressor.
ExplorerTom
Colorado
With engine off, spin the AC clutch by hand. Can you feel the resistance change as you spin? If you can, this is a compression cycle. If you can’t, compressor is toast.
JimR_TN
Middle TN
Are you sure the compressor is engaging? Any noise? What is the change in the low and high pressures?
RBalboa
Brownsville, Texas
I took my 2014 Expedition to my favorite AC shop, tech quickly diagnosed the problem as a bad electrical connector at the compressor. He soldered in another one and has been working great since.
