2023 Ford Expedition Gauges
Does anybody else have this problem with the four gauges above speed/tach gauges? If I delete boost and add trans temp gauge it stays that way until I turn off the vehicle, then when I start again it's back to boost. I heard it was fixed in update 22293 rev 710 back can't confirm with Ford. I turned the problem into Ford but who knows if they will fix.
RacerBX1
SE Michigan
I can’t remember when it changed, but seems like sometime this year in one of the bigger updates the small gauges above the large ones started staying like they are supposed to. Mine when changed will now hold that change.
jjscsix
texas
Mine is the same. Sadly i still have not gotten the Synch 4 update that came along 7-8 months ago.
Twes
New England
I recently bought 2024 Expedition Limited Stealth and am having the same issue . I’ve read updates have fixed the issue but would like to think the 24 would have come with the updates already installed . I prompt for an update and it states it’s up to date. I’ve read in previous threads other members have brought their expedition to the dealership and after they no longer had the option to toggle between boost and tranny temp so I’m reluctant to bring it in. Also not a huge deal just kind of a pia to going through the menu settings every time I shut the truck off/on .
Hellwig
Software of my sync 4 is 23222 with rev. 966. It doesn't have this problem.
R
My dealer has a mobile service for some problems so they came out and updated Sync to the latest versions and the gauge still won't stay on trans temp, after key cycle it reverts back to boost. Real pain. My tech says if 6 or so people complain Ford will fix it. Who knows if that is true.
