00' Expy 2wd Lug Nut Turque?
TodzY2KExpy
Nawlins
How much and where do I find the correct lug nut torque spec for my Expy? I thumbed thru the owners manual to no avail.:confused:
abbyzdad
spokane, wa
Todd
the lug nut torque for your 2000 Expy should be 150 ft lbs.
ford used 12 m.m. studs from 97 thru 11/99 on both the f150 and expy. these studs have a torque spec of 100 ft lbs. all expys built after 11/99 thru 2002 have 14 m.m. studs--torque spec is 150 ft lbs.
hope this helps, brian
T
TodzY2KExpy
Nawlins
Thanks Brian!
Thanks for the info, just wondering where you found that info...?
abbyzdad
spokane, wa
Todd
glad to help. the info i have came from a book published by Bridgstone/Firestone called TIPS 2003 (Tire Inflation Pressure & Specifications)
brian
