relentless85
Hello, I am new to this forum. We recently purchased an 02 Expedition Eddie Bauer with the 5.4L in it. It has 125K on it. I am trying to figure out how I can tell if the water pump is working/pumping correctly since there is no real radiator cap.
The heater only gets luke warm in the front and rear of the vehicle. The previous owner replaced the t-stat and that did not help. I am concerned that the impeller on the water pump might be broken and not allowing the coolant to be pushed through the engine.
The temp guage on the dash reads normal but no hot heat. Yesterday when I drove the truck just for a few miles, I could hear the fan clutch engaged and i think causing the engine to load down.
Is there a way I can check to see of the coolant is flowing or if the water pump is working with out having to take the water pump off?
