If the pc board is removable from the holder it may be possible to repair your old board. If you can take a close up pic of the entire panel and any id's of the relays that would help.
if you see the one spot in between the two relays right below your thumb that is empty. it is clear from that pic that the relays are removable
Yea I agree, I've never seen a car with relays that couldn't be removed without changing the fuse box. There has to be a way to remove them. Actually it may tell you about it in your vehicle manual.
If you can you could alwys try and ebay it to recover some of your money
Ok, we stand corrected - another ******** idea from Ford.
Here is how you get around that. You'll need some soldering skills and relays. All you need to do is wire this to your old fuse block after removing the board mounted relay(s). Or you could use a fuse/relay box for multiple relays.
Hella HL87173 Weatherproof ISO Mini Relay Connector With 12" Leads - RallyLights.com
