16inch ION WHEELS on expedition
ldutton6
NH
Hey Guys,
Just bought a set of Black Ion 174 wheels and was wondering if anyone has any pictures of theres with these?
LEAVE THEM IF YOU DO!!!!
Mikes05expy
Toledo, Ohio
Not a great pic but this is all I could find on the forum. It's another members ride not mine btw.5evetype.jpg
Sent from my S5
Pedition2000
North Carolina
The 16" will fit our trucks? I have 17" but have a big choice around here of 16" or 16.5". Thanks.
Lightnig
Behind you
absolutely 16's will fit. Can't speak to aftermarket 16" though, you would have to check for brake caliper clearance.
I know for fact 16" Ford wheels will fit, because that's what mine came with from the factory. Searching around for a local set of 17"'s though, just not feeling the love with 16's...
oregonn8v
Portland, OR
It may not be an issue for anyone here considering the change but do be aware that changing from 16" to 17" will reduce towing capacity by around 500# and vice-versa.
01yellerCobra
San Diego
Why's that?
Misspelling brought to you by tapatalk
Yudaman
Southern Oregon
Yes, why would going to a smaller wheel change your towing capacity?
If anything, the smaller radius if the wheel should INCREASE the capacity of the wheel (due to leverage on the shorter radius).
For years upon years the most widely used wheel size on work trucks was 16". Look back to any 3/4 or 1 ton truck before the year 2000. Everything had 16" wheels with an 8 lug bolt pattern. Therefore, it is still incredibly easy to find 10ply tires for use on a 16" wheel.
Hate to tell you, but your information source is incorrect. 16" wheels will not give you any less towing/hauling capacity over a 17".
Mediamonkey11
Enumclaw, WA
He's saying going up in size will decrease it, I bet that's based on a larger total diameter tire being installed which would make sense... But who pays attention to those numbers anyway ;-P
BIG GREEN FORD
loxahatchee Florida
I don't know about what you guys want to tow behind your truck but I pull my 42 foot boat around 8000 pounds and my buggy around 7000 and bobcats. With no proploms and I have 315/70/R17
Mediamonkey11
Enumclaw, WA
Haha my point exactly ;-)
I must see pictures of this boat on your expy!
oregonn8v
Portland, OR
Sorry if my post was not clear. I was stating that the 16" wheels will give you about 500# more towing capacity than the 17" wheels. You are right that the typical size for wheels was 16" for that reason. While no source is perfect, I tend to use Trailer Life Magazine's Trailer Towing Guide as a point of reference. This link will show Trailer Life's Towing Guides from model year 1999 - 2014.
For the 2000 Expedition 5.4L 4X4 Trailer Life gives three different tow ratings
6,400# with a 3.31:1 axle ratio
6,900# with a 3.55:1 axle ratio and 17" wheels
7,400# with a 3.55:1 axle ratio and 16" wheels
Mediamonkey11
Enumclaw, WA
Aah makes more sense, I thought you may have been referring to ratings based on wheel size, I'm wondering if those ratings are affected more due to the overall circumference of the wheel/tire setup rather than the rim size?? Hmmmm lol
oregonn8v
Portland, OR
If most of your towing is in Florida then you have fairly flat ground and I have no doubt you can tow that capacity. I would be hard pressed to pull 8000# with my Expy over Mt. Hood with a 6%+ grade and elevation of over 4000 feet. At least not at any reasonable speed. :imo:
Lightnig
Behind you
Absolutely
Wheel size does not make a lick of difference in that regard, it has everything to do with overall diametre.
It's all about ratios, think of it in terms of rear end gearing: A smaller overall tire will have the effect of numerically raising the gear ratio, as opposed to a larger will numerically reduce gear ratio - which is exactly why the guys with very large off road tires have to change their rear gears to something steeper (Numerically higher) to make up for the loss of torque due to the larger tire size (a bit of an over-simplification, but you get the idea).
BIG GREEN FORD
loxahatchee Florida
Yea that is also a big difference. The only thing I do is go through mud and dead sand and for short distance with the buggy on my trailer. Or the wet pavement pulling my boat out at the boat ramp but if I put it in 4low I don't even step on the gas
BIG GREEN FORD
loxahatchee Florida
And 3.73 gears? With 17in tires
