Can you just go test drive a dealer one with 22s to get an idea before you spend a few grand? Keep in mind potential damper differences between yours and the dealers, as well as air pressure. I just had mine serviced yesterday and they put 42 psi cold whereas I normally run 36 psi cold without payload. That 6 psi made a lot of difference on the drive home with our crummy roads.I currently have 18s on my xlt and want to install 22 inch stealth wheels how much worse will the ride be ?
Well, you could swap your 2015 wheels onto your 2018 assuming it's the same bolt pattern, offset, etc (I'm new to Ford trucks and don't know much about them) and try it out!I have a 2015 with factory 22s with ccd but my 18 doesn’t have ccd so I’m trying to find out and dealer doesn’t have any with 22s without ccd
