driver side window had had come loose from the metal clamps awhile back. My attempted repair failed. Left the window up until I could do a proper repair(suggestions welcome on that one).
Yesterday the window was lowered by mistake . I found the track that mounts to the glass clamps on the bottom of the door and the glass had stopped on the ball studs of the "X" regulator arms. Seems the tracks plastic guides popped off the ball studs that are rivited to the X member.
Unable to pop the plastic guides back on the ball studs. Appears to me the plastic guides went on the studs prior to the studs being mounted to the "X" arms. That makes no sense to me, but looking at the studs they are ground flat on the outer side to be flush with the plastic guides. Any clue on how to get them back on? Or do I need to buy a new "X" arm assembly with the plastic guides installed?
