2000 Expy charging problems
bocco
Livermore, Ca
Today the battery light came on in my 2000 Expedition. It showed low voltage at the battery when running so I assumed alternator and changed it. Still have the same problem. Starts and runs fine but only reads 12 volts at battery when running. Alternator field fuse is good and fusible link appears good. Any ideas?
B
bocco
Livermore, Ca
I think I figured it out. There are two connectors to the alternator, one three pin and one single pin. I reseated the three pin connector and the problem appears to be solved.
1955moose
Sounds like you've got corrosion at that connector. Your going to want to clean it up, and maybe squirt a little dielectric grease in there. The grease will help to keep moisture out, and a sound connection.
B
bocco
Livermore, Ca
Does anybody know where I might find a replacement for the alternator wiring harness? Looking all over and can't seem to find one.
RjNomar27
South Dakota
I have been looking at the "big 3 upgrades" on YouTube. That should help.
Sent from my SM-N960U using Tapatalk
stamp11127
Temple, Georgia
Best place is a junk yard. If it is a pull it yourself yard you can get as much of the wiring you need. If you just need the connector those are available on line. Dorman may make a pigtail.
