Transporter
NOTE: If Mods find a better place for this feel free to move it. I went though a bunch of the Electrical Threads and mine is kind of different.
Problem: Battery reads 13.9 volts at start of week. Charging System Warning then Battery Icon come on. Both go back off while driving. I have an App that reads battery voltage and it did drop down to 12.5 while the light was on, then the Icon went off and App shows 13.5. Next trip trucks starts and runs fine, App shows good voltage no warnings or Battery Icon. Half way through next drive, App shows voltage at 13.5 then I get the warning, then Battery Icon, then App starts reading 11.17, then back to 13.5, then 13.7 and warning and Icon go away. This repeats until yesterday.
I go out to start the Expy and it will not start. I check the battery with DMM and it shows 10.8 volts. Take out battery and go to Auto Zone and they give me a new battery as I have 5 weeks left on my total free replacement before the 2 year pro-rated part starts. Everything seems fine now. App shows 13.9 while driving.
This morning, drive to the Airport and everything is fine. Stop at a hotel to use the restroom before doing the loops at the airport to pick up the better half who's flight is coming in. App starts showing 12.5 then goes purple meaning it is below 12 volts for it is showing 11.5 and the warning and Icon both go off. Pick up better half, App is showing 11.17 again. I have been home an hour and the truck will start but the voltage on the DMM is showing 12.5 at rest. Which means it isn't charging. Warning and Icon were on at start-up this time.
Lastly during all of this the Alternator Meter on the upper right of the instrument cluster stays in the good range for charging. Does this tell us anything. OBDII is not showing any codes. Is the dash meter just to tell if the Alternator is charging but not that the charging system itself is working properly?
Where should I start troubleshooting this to start eliminating what it is not so I can find what it is? One side note, with my last battery change 3 years ago, I had to do the positive terminal mode has the terminal was completely fused together and I could not get it apart. So I have a battery post clamp with a vertical bolt to put the three cables on including the one that used to have the used to have the bolt as part of the connector that the other two went one. The old cable that used to have the bolt now has a hole in the spade to go over the bolt on the new battery lug.
Thoughts and suggestions?
