2007 no crank no start after running
reecy
El Dorado, Ar
So far I have replaced the starter, starter relay, diode for the one touch start, the switch & the computer. It appears to be losing the start voltage between the switch & the relay.
When it is hot you can roll the key to the start position & nothing happens. Second try the starter engages & kicks out after a couple of tries with the starter kicking out it will start in limp mode. I am at my wits end. ANY HELP WILL BE MUCH APPRECIATED!
R
reecy
El Dorado, Ar
Also the one touch start is not working properly. The key has to be held in the start position even when cold
tifanydire
