2016 Suspension Question
zac langston
Florence, Colorado
Hello,
I saw another post in here asking about suspension on the expeditions. I was hoping to get some similar help.
I do not know how to use a forum, so hopefully I get it right...
We recently purchased a 2016 Expedition, King Ranch EL, 4x4. I was initially under the assumption that ALL King Ranch's came stock with LLS (Load Leveling Suspension) Much to my dismay, I hooked the camper up this weekend and found that to be not true.
After and incredible amount of research and several phone calls I have discovered there is little to no aftermarket support for any suspension modification to these Expeditions. I only found ONE place in the United States that offers something other than stock stuff. Air-bag-it.com will build a "strut-bag" to replace the spring/strut in the rear of the vehicle and sell you an air compressor and an lcd and/or gauge to regulate the strut/bag from in the cab. While this is an option, I am not a huge fan because it does away with the coil.
I turned to more than one (x3) local Ford dealership for help. That was nearly a waste of time. No one in the dealerships can tell me anything about these vehicles. Nor do they seem to care. It is absolutely amazing to me that there is such a lack of knowledge. All three dealerships referred me to the window sticker to try and determine what I had for suspension.
I wanted to know if it was possible to take off what I have and replace it with LLS. They all told me it would be to expensive and to just go buy an aftermarket air bag and place on the vehicle. I had an overwhelming feeling that they had something better to do and were just trying to get me off the phone. I had to educate ALL of them that was not possible given the independent rear suspension set ups.
My closest dealership finally looked into it for me. I was priced right around $2,000.00 for all the required parts and an unknown amount for labor. Then I was told that it was unclear if the ECM would communicate with the system since the vehicle didn't come stock with it. I told them I wasn't a tech savvy guru nor a gear-head, but that surely that could be done. I called dealership #2 and they told me that kind of stuff was all stored in the BCM and that the BCM was programmable... that you could add, remove, or delete programs into it.
Upon further investigation I discovered these vehicles come with 3 suspension options total. You can choose from stock, LLS (load leveling suspension), and CCS (continuous control suspension). I began looking into the CCS. From what I discovered, it appears to be more complex than the lls, but I am not 100% sure on that. Either way, I think I will be staying away from this. During my research I discovered the Nivomat shocks/strut.
This is what lead me to this website and forum. Someone had asked a similar question and someone on here replied with a part number for that guy and told him exactly what he needed. So, my question is, does anyone know anything about the Nivomat shocks? I cannot find anyone that sells them with any knowledge. The particular one I am looking for has the accumulator in the top of it that builds pressure up and stores it in the accumulator chamber thereby creating resistance and aiding with rear end sag. you have to create bounce on the vehicle to get it to work. When you initially hook up your load, it will sag, the website (and your owners manual) direct you to drive the vehicle for approximately 1.5-2 miles to get the shocks "built-up" and to start working properly.
To clear the air, I believe the expeditions that have a Nivomat shock on them do not necessarily have this particular shock I referenced above on them. The company makes regular shocks/struts, but this one described above seems to be the cats meow. I did talk to one suspension company that had some familiarity with them, but he told me they didn't sell them and to call my local dealership. He explained that they are about twice the diameter of a standard shock/strut... like slightly larger than a pop can. I was told you have to change the coil to a lesser than stock coil due to the fact that the Nivomats work so well. If you retain your stock coil, the ride while not under load will be too rough. I found replacement Nivomat shocks out there, but they appear to be "standard."
My thought here is that if I can figure out this Nivomat shock/strut/coil combination they can be bought; pre-packed and installed in the existing location of the stock shock/strut without any serious modification to the vehicle.
I might be chasing a goose here. Not sure. But if this is doable, this might be a solution for others out there trying to do the same thing.
Any and all help is much appreciated. I apologize for the long reading. But I have done an incredible amount of my own research after the lack of help from the "industry professionals."
LRNAD90
Maryland
There are likely guys around here with more knowledge than I on the subject, but the 2016 Brochure indicates Load Leveling suspension is an option on all trim levels (XLT, Limited, King Ranch and Platinum), and standard on none.
I'm pretty sure that the Factory Nivomat load leveling shocks should be able to be purchased directly through Ford, and are likely a direct bolt in. Its just a matter of tracking down the right part numbers..
Z
zac langston
Florence, Colorado
Hello again. Thank you for the responses.
I have continued to work on my problem and FINALLY came to a solution. And I ended up basically doing it all myself. I went in a really really big circle to get there, but none-the-less, I got there.
After researching the Nivomat shocks to the end of the world, I almost gave up and stumbled upon ZF Products in Illinios. I found out they are the U.S. distributor for the Nivomat shocks that are made by SACHS out of Germany or France. (Not really sure) I was able to get a hold of technical support here and the guy told me they do not make Nivomat shocks for Ford. He told me GM used them on Yukons & Suburbans. I was obviously disappointed, but I did not give up.
I started looking through the vehicle specific catalog on Parts.Ford.com and stumbled on the Nivomat shocks. I couldn't believe what I was looking at. I called Ford Customer Service to see if I could get some verification and got no where. That was a waste of time. I called ZF Products back & talked to the same guy, he told me that Ford had most likely bought the engineering from SACHS and that's why he couldn't see anything about them. He reminded me that he couldn't help me.
So, I called my dealership back, again. I explained to the parts guy what I was after. Now that I had some part #'s off Ford's website I had some ammo to talk to the guy and tell him what I needed.
It get's interestingly hairy here. I wanted to share this with whoever reads this because I didn't know this. When you look at the Ford Parts website, the part #'s listed there are not necessarily the ACTUAL part #'s. They are "base" #'s. Getting the actual part # is much more difficult. For example, the # on the website for these year vehicles for the Coil spring is 5560. No matter what suspension type you look at (CCS, LLS, Stock) all the coil #'s are the same on the parts diagrams. The actual part numbers have letters & numbers before and letter & numbers after the 5560. In my particular situation it is EL1Z5560A. Not just 5560.
So, for anyone interested in "upgrading" the stock suspension, the Nivomat # you need is EL1Z18125A. Which interchanges with ASH24550.
I made the mistake of thinking this number was going to get me the entire assembly. Unfortunately, that is not the case. You have to buy ALL The other components with it to get this thing in your vehicle. My dealership quoted me $841.00 per side. I searched online (extensively) and found everything I needed through Amazon & TascaParts.com. Tasca Parts was awesome because the OEM part numbers the guys at Ford gave me crossed with no problem. I had no success with RockAuto, Carid, or AutoAnything, O'reilley,, Autozone, and a few other local spring & suspension shops. Through Amazon & Tasca, I spent around $600.00.
Lastly, just because... Ford wants $354.00 a piece for these Nivomat shocks. They were $162.00 each on Amazon. But I could only get one...(dang-it) I had to but the other one from Tasca for $201.00
Cap- part # EL1Z18A099A
Insulator- part # EL1Z5536A
Spring- part #EL1Z5560A (also significantly cheaper on Tasca website)
Shock- part # EL1Z18125A (or ASH24550)
There are some nuts, bolts, washers associated with this, but get those from your local hardware store.
Hope this helps someone else out there. I spent a lot more money than I wanted, but given there are NO OTHER OPTIONS on the market at this time, this was a heck of a lot cheaper than trying to talk my dealership into putting the air suspension (LLS) on the vehicle.
I haven't put anything on yet. Hope it all fits.
Randymac
Tennessee
I'm curious to know your outcome. I have a 2017 Limited that has the factory load leveling suspension. I replaced a 2011 Limited that towed well, but I wanted a newer model. I have a 5 year old travel trailer (spec is about 6000 lbs and about 550 tongue weight) I bought new and have towed for probably 15K miles with the 2011.
When I hooked up to the 2017 it sags. I drove it about 15 miles so it can can "level", but no difference. I took it to the dealer, and they were unable to get any info from Ford. I am told 1. It is not designed to level the vehicle. 2. They have no way to test the shocks to know if they are working. 3. I'm SOL. When towing on new blacktop I have no problem. On less than stellar roads it may be like towing a caterpillar. I have tried adjusting the WD Hitch. but since it is dependent on a suspension that is supposed to adjust itself, how do you account for that? THIS LOAD LEVELING SUSPENSION DOES NOT LEVEL, AND I AM NOT HAPPY. This Ecoboost has much more towing power than my v8, but I cant recommend this 2017 Expedition for towing with factory suspension. I too am having trouble finding an aftermarket solution. I think my only option may be a heavier strut If I can find one.
Dr0idattack
Bentonville, AR
I tow 5000ish travel trailer without sagging on a 2013 Limited, using an Equal-i-zer WDH. And it handles well.
I also have E class light truck tires and Bilstein shocks.
Load leveling suspension helps somewhat, but it doesn't redistribute weight.
A helpful video:
Z
zac langston
Florence, Colorado
Randymac,
Well, that is actually discouraging news. You are the first person I have met that has that suspension. So, you are the only one I know with an experienced opinion. I am hopeful my outcome is better than yours. I am curious what kind of shock you actually have...
I was told that I had to down-grade my stock spring with the Nivomat self leveling shock. The research I did said that if I didn't, the ride would be too rough while no load was on the vehicle and that the Nivomat does "such a good job" that you have to go with a lighter spring. Perhaps I will hang on to my stock stuff for a while until I have the chance to test it... Maybe I will stick it back on if I don't get the results I am looking for... maybe...
This might sound silly, but as soon as I get mine installed I was going to have my wife hold a tape measure on the receiver hitch and then hop on the bumper up and down to see if I could get the bottom # to eventually climb (given the theory behind how the load leveling is supposed to work) Not sure if this is going to work, but I did this the other day and with the stock suspension I can get the vehicle to "bounce" 3". (I weigh about 220lbs)
The other thing I was directed to do was to buy an Equalizer hitch. This is a load leveling hitch, made by Equalizer. Sort of hard to find... another company makes one with a similar name... Sort of difficult to depict which one is which online. But, if you can find it, research it. They are pretty interesting. And VERY expensive. They are not a chain attached system. It's kind of neat. They claim the chains are bad news... But who am I to know that...? I will be purchasing one eventually, however given the high cost, I am going to have to save up for one before I do it.
Randymac
Tennessee
The original window sticker lists the load leveling shocks as an installed option, but I have not verified that that is actually what is on my vehicle. Shocks have a FoMoCo sticker with numbers EL14-18W002-NNA. 894104000740. Made in Mexico
Z
zac langston
Florence, Colorado
Hello Randymac,
I took the liberty of looking your part # up and found nothing. So I called the guy at my local dealership that helped me behind the parts counter. He did a cross reference search. He claims that # you have (EL14-18W002-NNA) is an engineer # (whatever that means...) He was able to cross it and found EL1Z-18125-A for a part #. He verified it as 'self leveling rear suspension'.
I cross checked my recent order. You have what I JUST ordered.
I am really interested to see how this all works out for me. I am discouraged about your experience. I am slowly becoming doubtful that mine is going to be any better... but I hope so...
Thanks again for the info and for replying to the post. I appreciate the input and info.
Z
zac langston
Florence, Colorado
Hello Randy Mac,
I received everything I ordered about a week and a half ago. We went camping that weekend so I didn't get the stuff installed. This last weekend I pulled the expedition in and tore it all down. Only to discover that the caps I purchased for the spring/shot strut assembly were not the right ones. (DAMNIT!!) I tried to make the "stock" ones work that were on the car, but it wasn't happening. Putting all that back together was a real treat! I don't have a coil spring compressing tool, so I went at it with a standard shop press. Not the safest way to do it, but it worked. (I will be borrowing a coil spring compressing tool next time...)
So, I had to order the correct ones and am waiting for them to ship. For some reason they are EXTREMELY hard to come by. There was only 1 showing in the Ford warehouse and a few at several different dealerships across the United States.
I am waiting for them to e-mail me and tell me the parts are on back order...
Hope that doesn't happen, but who knows.
I fully intend on getting back on here and sharing my results.
17limited
TN
How do you identify if your vehicle has the factory load leveling setup?
I ask because mine has a small what I assume to be air pump behind a grille in back drivers side of cargo area
99WhiteC5Coupe
I have a 2015 Ford Expedition Limited 4x4.
Read your vehicle owner’s manual - the item behind the grill in the rear, left side, is a the fuel cut-off switch.
34Ford
North Carolina
I have a '08 king ranch with LL shocks and I can hear the compressor run somewhere in front of the firewall.
Now my '17 has the stupid CCD suspension.
Z
zac langston
Florence, Colorado
Hey RandyMac,
I FINALLY got the suspension installed this weekend. I was correct about the parts I was waiting for from Tasca.com. They did in fact back order the parts and I had to find them elsewhere. That was a pain. I have to change my opinion about Tasca.com. I waited and waited and waited for them. We attempted to call them several times. When I finally got through, the guy I talked to told me the parts were not available and had not been available for some time. He was curious as to why THEY hadn't told me that. (Very frustrating.) My local dealership ended up ordering them from a dealership in California. I had to wait forever for them. I also was not able to come up with the correct washer for the top cap, so I ended up making my own.
My initial opinion of what I have done is discouraging. I gained about 3/4" in ride height, but other than that, there is little difference in the suspension and the ride of the vehicle. I did take the vehicle out in the back forty and hit several bumps to try and get the car to bounce. When I got back in the garage on level ground I measured it again. I had gained about another 1/4"-1/2". For a total of about 19-1/8". I let the car sit for a while and came back to measure it again about an hour later. It had dropped back down to the initial ride height. So, bouncing the car down the back forty road did adjust the ride height a little.
Here is the most discouraging part. When my wife got home, I had her hold the tape measure while I jumped up and down on the bumper. I wanted to test my understanding of how the Nivomat shock worked. And I wanted to test the theory that they build resistance as the internal accumulator builds and stores pressure. With no weight on the car, the new receiver hitch height measures 18-3/4". I weigh about 220lbs. I was able to bounce the car down to about 16". I bounced and bounced and bounced and bounced. No change. I bounced until I couldn't anymore. No change. I was at 16" on the bottom end and about 18-3/4" on the top end.
I thought the bottom end number would climb as the suspension "built resistance" in the accumulator. I am no Ford engineer, or a tech guy; and I know my test is simple. But it seems like it should have worked. I saw no change. Which sucks. I have nearly $1,000.00 into this and it appears to have made no difference.
I have not towed with the vehicle yet. We are planning a camping trip over the upcoming holiday weekend. That will be the first opportunity I have to get a load on the vehicle. I am going to follow the owners manual instructions and hook the car up, then go drive it for a few miles and then hook up my weight distribution hitch. Hopefully the new suspension will take the road bounce out. But I will not know that until I try it.
As of right now, I would not recommend anyone do what I have done. It appears to have yielded me no change and has caused nothing but a bunch of aggravation and stress. I cannot express how frustrated I am with the lack of knowledge out there in the industry. Particularly the Ford people. I spoke to NUMEROUS individuals about this and no one knows a dang thing.
The only thing I can say as a warning to everyone else it to make sure and double check what you are buying. I made a HUGE mistake. I fully and whole heartedly believe the true air leveling suspension is the way to go with these vehicles. The 08' we upgraded from handles my camper WAAAAAAY better than the 16' we upgraded to. However, the old 5.4 motor in the 08' is nothing in comparison to the new eco-boost motor. No comparison.
Dr0idattack
Bentonville, AR
Man that’s a tough expensive learning experience.
I don’t know about Nivomats; but Bilsteins plus E-class tires plus the E4 12000 WDH for my 2013 made my towing and ride experience way better than when I started stock. I considered looking into air leveling, but sort steered away based on my research (and didn’t want a compressor).
