2017 factory brake controller
chuck s
The factory brake controller does more than stop the trailer (which the P3 will do wonderfully). The first time I connected to my camper with the '17 truck the dash display informed me a brake light on the trailer was out (it may have told me which one). And it has the ability to setup and store several trailers with different brake configurations.
The factory brake controller may be an integral part of the trailer sway control system as well. This same trailer suffered a catastrophic tire blow out (not merely a flat tire) at speed on the Ohio Turnpike. I thought I'd been struck from behind. Pulled safely to the shoulder of the Turnpike. Guys repairing the tire complimented me on my driving skills getting safely off the road. Heck, I just put my flashers on and pulled over without additional excitement. Laying on my belly on the shoulder to change the wheel I discovered a surprising quantity of gravel and small metal parts off other vehicles. A 1-12 ton Harbor Freight floor jack travels with the trailer -- first time I needed it.
Tires were all at proper pressure but were old. I knew better than to run ST tires older than 4 years but was sure I could get away with the tires 'cuz they looked good. Entire section of tire blew out. Some damage to the trailer underside but the tanks weren't touched. Five new tires on new wheels went on the trailer a few days after aborting the trip and parking the trailer in my driveway.
-- Chuck
Don Plata
Missouri, USA
-- Chuck
This is exactly why I wanted to get the integrated controller to work! Can't wait to use it this weekend!
Jim Johnson
Ohio
Bringing this thread back from the dead because it's hard to find good information on the internet on this particular thing for Expeditions.
What I found is that the F-150 spreadsheet for Forscan works just fine. As does the controller if you can't find an Expedition specific one. The problem with the F-150 one is it's tapered oddly and will require a bit of fitting for the bezel to snap in cleanly but it's easier to find and when you have to have one you have to have it. I did a four wire to seven wire conversion plug and just spliced in the brake control wire. It's easily the nicest brake controller I've ever used and well worth the effort.
No additional power to my toy hauler and I plan to address that with a Harbor Freight solar panel and and a deep cycle battery. For now we'll just use my battery charger and top it off in about an before we hit the road. It sits outside all week and only sees use on Friday nights. Over the off season it's stored in a barn. Since my trailer is also set up for 110 generator power as well I always have that option.
The toy hauler is used as a band trailer. It's a full-height 20 footer that weighs somewhere around 3,800 pounds empty. With the equalizing hitch you can pull it like there's nothing back there. Granted, it's a great trailer but the Expedition is a really nice tow vehicle. I would have never believed it out of a six cylinder. We had considered trading it down for a smaller trailer but that's off the table now.
DExpy17
MD
My local dealer told me the same thing after having my ‘17 Xlt El for 3days. I gave up and bought a hopkins 7 pin and brake controller and had that working in 20 minutes.
mquick5
Buckeye Country
My Uncle just upgraded or d/graded trucks. He had a 2013 Limited F150 with the factory brake controller. Traded for a 2017 XLT F-150 that didn't even have a hitch or plug in the rear. He added the hitch and 7 pin hookup, and towed his 28ft camper through the mountains with no brake controller, like it was nothing. He said he was told the truck didn't need anything extra. And imo the transmission seamed to do most of the braking. All I have is a utility trailer, that I tow atv's on. It's just a single axle, so I don't need brakes. Plus the wife won't let me hook nothing to her new Expedition, lol! Anyway the dealer my Uncle talk to lead him to believe the truck didn't need anything? Not like a couple of you are saying, that you were told they don't make a controller for the Expedition.
iimagine
2016 EL XLT
FL1Z-2C006-D is the part number.
chuck s
The F150 controller will drop in, Forscan can set this up and the wiring may already be there.
Towing a 28ft camper thru even the Ohio "mountains" without working brakes is irresponsible. No doubt the truck can tow it but stopping it in an emergency is something else. Trailers in this size range are legally required to have brakes and no doubt has electric brakes. Since the trailer lacks surge brakes the implied (and no doubt legal) requirement is the tow vehicle must be equipped to activate them and hooked up. There are liability issues here too.
The Expedition and F150 can easily handle brake-less light utility and boat trailers. The best boat trailer brakes are electric activated hydraulic. Uhaul trailers typically have surge brakes.
-- Chuck
mquick5
Buckeye Country
Chuck,
Yeah I was worried about it for sure. And this wasn't in Ohio, we drove from W.Va through Ky. & Va. then to Tnn, and back. Seamed to stop fine, but I wasn't driving.
Sent from my SAMSUNG-SM-G870A using Tapatalk
Garyyuan
TX
Me 1 Dealer 0! ForScan worked wonderfully! I went into the As-Built and changed the numbers as suggested on the spreadsheet. 8 for the Brake controller and 4 for the Gain. It was fantastic! Connected the 7 pole and immediately got the trailer connected notification on the dash. Tapped the brakes and got notification of the gain.
When I connected the OBDII to the computer and ran Forscan, every time it asked me to switch from HS-Can to MS-Can the program would crash and close. I just selected, I did not have the MS-Can toggle and it finished with just the HS-Scan and I was able to make the change in the IPC As-built. Some videos showed just click and play on the IPC module, but when I did that the Trailer brake controller didn't show up. So I clicked and played the IPC As-built and located the matching codes to change then wrote all. Worked like a charm! Only $30 for the OBDII and now I can check on error codes and do other things if I so desire. Oh don't forget to get the extended license of ForScan to do the module work. It is free as a forum member.
Thank you Black, Chuck S, and Char17EL for the help! Gave me confidence it would work!
I also found this on the ForScan forum site that gave me confidence that it would work.
f=16&t=5425&p=24158#p24158 https://www.forscan.org/forum/viewtopic.php?f=16&t=5425&p=24158#p24158
Also I got notification today from the supplier I got the Factory brake controller from that they would not take my controller back since it was an electronic that had been opened. So I had nothing to lose but in the end saved a quite a bit of money.
Don, I really appreciate you pioneered this work! I'm also planning to add the OEM TBC to my Expy 2017 too. But all of first, could you please share how to install the TBC to the cubby? I only found a demonstration on F-150 on Youtube as below. Are the steps similar?
Thanks,
Pyle
gtncpa
NJ
I went from a 2014 Expi with heavy duty towing package to 2017 Expi with the same towing package.
The biggest difference appears to be the multiple options that you can set using the left screen on the dash. On the 2014 the only thing I would set was the braking from 0.5-10.0.
There seems to be many more options on the 2017. I have not explored them yet. Is there a good video around that explains how it works?
Don Plata
Missouri, USA
@pyl
Thanks,
Pyle
I am so sorry, I have been really busy and not in this forum for a while.
I did not have the plastic non-marring tools to pop out the cubby from the front, so I went from behind.
The switch out of the cubby to the TBC was really basic. I used a flashlight and looked up from under the steering wheel and followed the backside of the dash up to where I could see the TBC wiring harness attached to the back of the cubby. Once, I knew where the cubby was from the backside, I reached up then pushed up and out on the bottom tab of the cubby. The cubby then popped right out the front. Then I removed the wiring harness from the cubby and plugged it into the back of the TBC then pushed the TBC into the cubby spot until it clicked into place. Before you put the TBC make sure the +/- is on the right side and the override lever is on the left.
This may be too late for you. I apologize. Hopefully it will help some one else. I can get some pictures and attach, if needed.
Garyyuan
TX
@pyl
Thanks Don! I figured it out and shared it as below. Actually I have enjoyed a camp out with it already :)
https://www.expeditionforum.com/thr...controller-on-my-2017-expy.37376/#post-321975
-Pyle
Expy00
California
So not finding a 2107 Expedition EL with the Heavy Duty towing package, and the help from this forum, I bought yesterday a '17 Expy EL XLT 4WD with the 3.73 axle ratio. I plan to tow an 8600 lb trailer and will upgrade the xmission cooler, radiator and install the factory Trailer Brake Controller (TBC).
TBC question: I entered part no. FL1Z-2C006-D from this post and options to check for my vehicle (2017, Ford, Expedition were the only choices). The response was "It fits your vehicle."
There was an option to enter VIN to which the reply was it does not fit. (?)
I then researched the find related parts and found this one: FC3Z-19H332-AJ
replaced by: FC3Z-19H332-C
that fits
1FMJK1JTXHEAxxxxx 2017 Ford Expedition6 Cyl 3.5L GTDI; 6-Speed Automatic Transmission (6R80) Four Wheel Drive (Part Time) Extended Wagon.
Has anyone else experienced this part change? Does 4WD or EL or 3.73 axle make a difference?
Thanks in advance. This forum has been very helpful.
chuck s
The HD Tow option may also include a stronger receiver (rear frame member where the hitch goes in).
Compare the data plate on the bottom of your receiver to mine. They may be all the same but this one is the HD Tow version on my "short wheel base" XLT:
Maybe upside down, I tried to flip it. :)
-- Chuck
Expy00
California
that fits
So not receiving an answer, I purchased part number FC3Z-19H332-C. DO NOT MAKE THIS MISTAKE. It is a trailer control module but not an in-dash TBC. I have re-ordered the FL1Z-2C006-D. Hopefully, this is the correct part.
(FWIW, I suspect using my VIN the FordPartsGiant.com confirmed my Expedition does NOT have that part so it is not a replacement. Just my idea,)
