2017 Ford El ticking
outdare
I tried to research this and found another thread that is dead. So here is goes. My El has 74,900 miles and is a limited if that means much to this. I was walking around and heard the ticking noise. Mostly passengers side wheel well. I heard the ticking when cold, but it is more pronounced when warmed up.
The ticking keeps pace with RPMS. Higher.the RPM the faster the ticking. I'll try to attach some video sound clips I have.
Thanks,
Outdare.
Added: I am using 5w30 synthetic oil. Next oil change is due at 75,500. I bought the truck used with 44k miles.
Sent from my moto g(7) play using Tapatalk
Cold start
Fans off
Rev
Passenger side
I’m not an EcoBoost expert but im not hearing anything excessive here. Has the engine sound changed recently and is the tick new?
outdare
outdare
Yeah the ticking is new and loud. Maybe I'm paranoid dunno.
Black
Kentucky
Sounds like every Ecoboost I have been around that has some mileage on it.
Mine included.
Shantheman73
Kansas City
That sounds like the cam phasers to me. Some owners say it gets bad enough it starts sounding like a diesel.
I know on the 5.4’s they will get loud on the passenger side first...since that’s the side that’s often starved for oil before the drivers side. Not sure if that is the same for the EB 3.5 but I wouldn’t be surprised.
What kind of oil filter are you using?
2007 Ford Expedition Limited
07navi
Mt.Shasta California
You need to look at an Ecoboost forum or Google it, I doubt if there is a lot of experience with it in here.
outdare
outdare
Thanks guys. I'll get the oil changed and see if it helps.
I saw this post recently. Just an idea, possible the HPFP (fuel pump) may get louder as they age because of lobe wear. Maybe? Maybe not? I don’t hear any cam phaser noise.
Langer
Chicago
It doesn’t sound terribly different than mine, I have ~72000 on my 2017. Doesn’t mean something isn’t wrong with mine, I guess. I don’t recall it ever sounding much different. If yours started all of a sudden the concern is valid. Tough to say whether it’s been there all along and you just noticed, or if it just started.
outdare
outdare
I'll get out some long extensions and see if I can track down the ticking noise.
outdare
outdare
The ticking is coming from the hpfp top driver's side rear. Also I am getting a audible noise from my pvc pipe passengers side front. I'll post some picks up later. I will try some fuel additive to see if this may be bad gas. Not sure if the pvc deal is normal or not.
Hpfp
Pvc
Now it is quieter
Just to compare.
Noisy
coolzzy
Idaho
What did you do to make it quieter? Mine had sounded like that since I purchased it with 34k miles. I'm now at 58k on my 17 EL, but have certified pre owned powertrain warranty till 100k so I figure if it craps the bed and needs timing components before then, it will only cost me the $100 deductible. I've heard many F150s sound exactly the same and I've also heard ones that are completely silent....
outdare
outdare
I just changed the oil and put in Lucas fuel additive. I topped the tank off with premium fuel. I normally run 89 octane.
MidwestBoater
St Louis
That sounds normal to me. I've had my '16 EB Expedition for 3 years and have put 50,000 miles on it (at 105,000 miles now), it's sounded like that since the day I bought it. The HPFP makes some noise as do the injectors. The fuel injectors in direct injected engines are quite loud.
Goldmember
Ottawa
I’m glad you posted this as I’ve notice the ticking noise as well. I have a 2017 Platinum El with about 75000km or 45000 miles and it’s been bothering me. I notice it when remote starting during winter time. It seems to cause vibration from something underneath. I changed the exhaust gear clamps thinking it was that. The sound seems to pickup and go as the engine idles. It also sounds louder as I accelerate slightly at the drive through and as the sound reflects back. I don’t think it’s normal as not all ecoboosts have this sound but I’m not a mechanic and this is my first ecoboost engine. Thanks for sharing.
ssmock
Kansas City, KS
Might be a cracked exhaust manifold. That was what my 2014 was doing, ticking noise and sounded like a lifter. Had it replaced under the Ford ESP warranty. Glad I had that as two exhaust manifold bolts broke (not uncommon) and had to be repaired. That was on the V-8 engine not the Ecoboost but worth checking.
libertycrab
Alberta
The bolt to hold on the header may have broken off and it is an exhaust leak like on the 5.4?
rjdelp7
2000 XLT
NY
Turbo wastegate rattle(check eng light on?), Cam Phaser/timing chain, noisey direct injection pump.
