2018!Failed right front wheel bearing
youngkicker
Fullerton, CA
I have owned multiple Expeditions over the years. No problems. Just had right front wheel bearing on 2018 XLT fail at 52,000 miles. Dealer has never seen this. Anyone have this experience?
I have a 2018 Expedition Platinum with only 38k miles in the shop now and bearing are rusted and shot they are telling me. I live in CA. Right side front. But they listed with a scope and think the left side is not far behind.
Lizzie
San Antonio
I haven't. Mine didn't fail till after I put spacers/bigger wheels at 230k. Did they mention why?
Deadman
Wisconsin
What did yours sound like as they were failing? Mine has started a sizzling type of sound from the front end area that almost sounds like tire noise, but its not the tires.
JasonH
Houston, TX
Sounds like a low rumbling sound that changes pitch as you turn. If you can find a sweeping highway turn, go around both directions at a moderate speed and the pitch will change as you turn the wheel. Last time one my mine failed it sounded like the passenger side but it was actually the driver side. You can also fee friction in the hub if you rotate it with the wheel off.
Deadman
Wisconsin
Thats what mine are doing now..... add me to the list.
ColoradoJon
Colorado
PXL_20231015_152733043.MP.jpg$2618 last week. Covered by warranty. I think you can do it yourself for under 1k or less if you do the bearings and not the assembly. Also consider additional damage internally. I think there are some potential issues with drive shaft or internal to differential?
JasonH
Houston, TX
How much does that repair cost? Just so I can brace myself.
Not sure, I did my own. It's not terribly difficult. The only thing is that the wheel hub can get seized in place, but there's a nifty trick for pressing it out that works well using some hardened nuts and bolts. Watch some YouTube videos. Any competent shop should be able to quote it without seeing it.
sharprd65
